Thread: Address 61 Battery regulator - Fault code 02252 Generator?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Sep 2011
    Lurking over a keyboard ...
    Hi Mark,
    Looking at you attachment of MVB 04 data window 1 your alternator may not be functioning. View description on this page Link:- Audi Portal: ECU Diagnostic . Audi A6 4F (2005- ) . Energy Manager J644
    What does data window 3 & 4 say in MVB 10 in module 61?
    Measured value block 010:
    Specified alternator voltage
    DF signal
    Alternator/ J644- energy management control unit interface (OK / not OK)
    Alternator (OK, not OK)
    ATB
    G
    0 2 0
  2. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Nov 2012
    Somerset UK
    Specified alternator voltage = 14.5
    DF signal 100%
    Alternator/ J644- energy management control unit interface = OK
    Alternator =Not OK
    So looks like the alternator itself
    Am planning to have a look underneath to get part no of Alt on Saturday, with this I'll see if I can change the Alt regulator and the Aux belt alone, if this doesn't fix it then an new/refurbished Alternator will be required
    Incidentally the aux belt made by Dayco (who make them for Audi) is a mere £20.12 delivered off ECP with their 'hot30' discount code ATM
    2 0 0
  3. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Nov 2012
    Somerset UK
    Replaced alternator regulator with the alt still on the car.
    All running OK now and alternator is charging the battery with no fault codes
    1 2 0
  4. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Sep 2011
    So glad mate it sorted, simply and easily by you
  5. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Nov 2012
    Somerset UK
    By way of an update, the car died on me again this week.
    Had the alternator tested (after me changing the regulator last month) and it was OK
    Had the old battery tested and it was ok, they said it was perfect and were surprised given it the original and 7yrs old
    Had the new battery tested and it had two faulty cells (it has 6)
    So lessons learned:
    1) just because it's a new battery don't assume that it will be perfect and have it tested.
    2) An old battery if conditioned correctly (CTEK in my case) can last a lot longer than its warranty states
    The battery place that did the test did so FoC and have even given me a note to say what's wrong with the battery so I can claim on the warranty, naturally I don't actually want a replacement but my money back, but will take the replacement and keep it fully charged for use at another time.
    Battery place also advised that battery cells can get damaged in transit, e.g. cells breaking.
  6. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Jun 2020
    Manchester
    Hi All
    update i am aware old post but 02252 generator was on my car a known long term fault with the wiring loom on the alt/gen
    Repeat known fault but was not fixed under warrant by 3 garages !!!Just left with an AGM batt notgettingenough voltsand thus needed a new AGM battery after just 3 yrs and low miles.
    This may help somebody.
    Two vw specialist could not fix the 02252 code.
    I managed to cross check with google translate and find on Russian forums and T4 forums that a new generator/alt cable is needed with modified parts.
    VW are fully aware of the faulty cable and why no recall!!!!
  7. Re: Address 61 Battery regulator - Fault code 02252 Generator?
    #17
    Nov 2020
    United Kingdom
    Hi all 02252 fault code on a Audi a6 2.7tdi allroad quattro 2006. Is there the same issue with alternator Cable .
  1. Please Help 1996 sharan gl 2.0 petrol, holding back and thirsty 00515 fault code?? also battery draining over night??
    By Benjamin Wright in forum Touran - Sharan - Caravelle
    Last Post: 27-12-2012, 08:05 PM
  2. Battery Regulator Question A6 C6
    By apole in forum VCDS - Help Requests
    Last Post: 06-02-2012, 01:23 PM
  3. Does anyone have a radio code generator?
    By Can-doo in forum In Car Entertainment
    Last Post: 05-02-2011, 08:01 PM
  4. Polo Window Regulator Fault
    By steveb_online in forum Polo - Derby - Lupo - Fox
    Last Post: 30-06-2010, 10:35 PM
  5. Please Help fault code 18010 battery terminal b+
    By yas_b in forum Polo - Derby - Lupo - Fox
    Last Post: 08-10-2009, 08:01 PM
