Thread: Address 61 Battery regulator - Fault code 02252 Generator?
Results 1 to 10 of 17
  1. Address 61 Battery regulator - Fault code 02252 Generator?
    Nov 2012
    Somerset UK
    New battery (the same one as Gups) fitted and I think coded correctly but am getting the following VCDS fault, along with the battery light coming back on after 10 secs
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4F0 910 181 E HW: 4F0 915 181 A
    Component: J0644 BEM H12 0590
    Revision: 00000000 Serial number: 00000000045843
    Shop #: WSC 00000 384 00290
    VCID: 23450ED1E2520406A65-8076
    Subsystem 1 - Part No: 402 092 316 2
    Component: von VA0 16062014AA
    Coding: 343032303932333136322056413031363036323031344141
    Shop #: WSC 12345 384 00290
    1 Fault Found:
    02252 - Generator
    012 - Electrical Fault in Circuit
    Freeze Frame:
    Fault Status: 01101100
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 111
    Mileage: 166262 km
    Time Indication: 0
    Googled but nothing conclusive
    Have cleared DTC's multiple times and keeps returning...anyone have an idea, does the regulator need some special attention after a battery change?
    Weird thing is that new battery was 80% and ran engine for 20mins and now reading 100% so clearly alternator is charging it.
    Will take somewhere & get alternator rechecked but would be grateful if anyone's had this before?
  2. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    46 Post(s)
    Can't find the fault code on Ross Techs website, send them an email for direct support.
  3. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Jul 2013
    78 Post(s)
    From what i read on the net it could be voltage spike from the alternator.
    Was the battery fully charged when you fitted it?
    Check to make sure that you have no other fault codes as other modules could have sustained damage.
    You should check the output voltage from the alternator as well to confirm that you are get 14.5 -15 v dc from it.
    Dan
  4. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Nov 2012
    Somerset UK
    Dan, yes it seemed to be as came from a high volume supplier and DIS was reading 100% in 10 mins
    Multiple electrical items showed up as faulty but cleared after a DTC clear
    Could the low voltage on the old battery have damaged the regulator itself.
    Intend to get the alt checked but can't be tomorrow as school sports day and both my kids takig part...so will use the Jaguar instead.
    Why does this forum censor the abbreviation for Jaguar
  5. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Jul 2013
    78 Post(s)
    It may have had a high current draw initially which caused a voltage spike.
    Which may have affected the voltage regulator, try looking at the alternator output using the VCDS scope tool to make sure that the output is a still at dc voltage.
    Dan
  6. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Nov 2012
    Somerset UK
    Wuzza 'scope tool'
    According to VCDS guru alt can't be tested..but that was 2012 and a lot may have changed?
    Can I use VCDS to check the alternator / battery charging OK ?
  7. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Jul 2013
    78 Post(s)
    Try and see if the battery voltage can be see using VC Scope with come with VCDS.
    VAG-Scope: graphing plug-in for VAG-Com
    Dan
  8. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    New Forest
    80 Post(s)
    I suffer from this. changed the battery, all seemed well but a few weeks later, problem returned. I suspect it's the glow-plug harness at fault, causing battery drain. However my fault code readout differs from yours:
    Component: ENERGIEMANAGER H12 0470
    Revision: 00000000 Serial number: 00000000002209
    Shop #: WSC xxxxxxxxxxxxxxxxxxxxxxxxxxxx
    VCID: xxxxxxxxxxxxxxxxxxxxxxxxxxxxx
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 1503090486
    Coding: 344630393135313035442056413031353033303930343836
    1 Fault Found:
    00532 - Supply Voltage B+
    002 - Lower Limit Exceeded - Intermittent
    Freeze Frame:
    Fault Status: 00100010
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 99
    Mileage: 233364 km
    Time Indication: 0
    Date: 2014.06.17
    Time: 12:54:08
    That said, I also get intermittent electrical problems after extended periods of rain, so you could have water swilling around in the car somewhere (see Gup's thread The most Lemon Audi A6 Avant strikes again) and that may be causing a leak to earth, which would flatten the battery.
    Q7 3.0 TDI Quattro (272 HP) S-Line
    (Gone) A6 C6 AVANT 2.7TDI SE MANUAL
    Hers - Mk. VII Golf '15' 2.0 TDI BlueMotion
  9. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Nov 2012
    Somerset UK
    Left for 2 days without driving and battery still reading the same
    Here's the full log of the fault:
    Subsystem 1 - Part No: # ÿ 00ÿ
    Component: von VA0 2703201326
    Coding: 142316062016FF3030FF2056413032373033323031333236
    5 Faults Found:
    02252 - Generator
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 3
    Reset counter: 110
    Mileage: 166262 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 14:26:24
    00992 - Consumption Cut-Off Active
    000 - - - Intermittent
    Freeze Frame:
    Fault Status: 00100000
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 166262 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 14:26:24
    02272 - Quiescent Current Stage 1
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 166262 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 14:32:27
    02274 - Quiescent Current Stage 3
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 166262 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 14:36:15
    02277 - Quiescent Current Stage 6
    Freeze Frame:
    Fault Priority: 7
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 166262 km
    Time Indication: 0
    Date: 2014.06.16
    Time: 14:36:25
    Battery light on dash kicks in after 15 seconds so would hazard a guess that my fault is either with the alternator or the battery regulator as SOC is at 30% but battery condition at 90%, generator voltage at 14.3v and battery actual at 12.3
    Glows in my case changed 4 months ago and no water to be seen anywhere, even had a look I the scuttle area near the firewall which is a known area for this
  10. Re: Address 61 Battery regulator - Fault code 02252 Generator??
    Jul 2013
    78 Post(s)
    That generator voltage is what it specifies and not the actual output voltage does the battery actual voltage change when tested with the car not running to a running condition?
    From the page 2 picture you are drawing 20 amps into the battery, this would indicate that the battery may have a duff cell in it.
    Maybe take it back to the supplier and have them confirm if its good as it's not it could of damaged something, and if the alternator is shot then i would be looking at them to settle the cost of a new one.
    What module did you get those measuring blocks under? Ignore this as its the 061 module which is not on the 2.0 facelift models.
    I have a 2.0l facelift model but maybe could compare values as they should not be too different.
    Dan
  1. Please Help 1996 sharan gl 2.0 petrol, holding back and thirsty 00515 fault code?? also battery draining over night??
    By Benjamin Wright in forum Touran - Sharan - Caravelle
    Last Post: 27-12-2012, 08:05 PM
  2. Battery Regulator Question A6 C6
    By apole in forum VCDS - Help Requests
    Last Post: 06-02-2012, 01:23 PM
  3. Does anyone have a radio code generator?
    By Can-doo in forum In Car Entertainment
    Last Post: 05-02-2011, 08:01 PM
  4. Polo Window Regulator Fault
    By steveb_online in forum Polo - Derby - Lupo - Fox
    Last Post: 30-06-2010, 10:35 PM
  5. Please Help fault code 18010 battery terminal b+
    By yas_b in forum Polo - Derby - Lupo - Fox
    Last Post: 08-10-2009, 08:01 PM
