Thread: turbo adapter clip hose no tight....
  1. turbo adapter clip hose no tight....
    Jan 2014
    london
    have been checking for boost leak on my 2.0 tdi engine
    i need to know if the turbo pipe adapter must be tight or have a little play i mean a bit loose
    need some advice check the video ..
  2. Re: turbo adapter clip hose no tight....
    Sep 2009
    Broxburn
    Looked at this and it doesnt look good - the outlet of the turbo should be secured as it is in fact a pressure line - if its loose then you will lose boost and that will result in a performance drop. See if you can have a look at another model and do the same ?
    The hose should b properly secured to the flange, that flange also looks kinda loose aswell - maybe some thread lock on the threads to secure if there it does screw in...
    2014 Andi 3.0 V6 TDi S-Line Quattro
    Full LeatherIHeated SeatsIElectric SeatsISunroofIMatt Brushed Aluminium InlaysIBi-Xenon HeadlightsIRear Park AssistIBluetooth
  3. Re: turbo adapter clip hose no tight....
    Jan 2014
    london
    Quote Originally Posted by ruggedscot View Post
    Thanks for reply
    are this causing the car to smoke ?
    I went to audi for the part they charge £160 for that turbo hose pipe + the adapter to turbo.
    where could I found this part for cheaper but good quality ?
    Sent from my GT-P3110 using Tapatalk
  4. Re: turbo adapter clip hose no tight....
    Aug 2008
    South East
    I agree, should be airtight
    Audi A6 3.0TDI S-line Le Mans Avant Tiptronic 2010. Phantom Black. Fully loaded.
    Audi TT 225 Coupe 2003.
    Audi A6 Avant 1.9TDI 130 Sport manual. Oil Catch can. Leather, RPS, cruise, Bluetooth, arm rest.
    Eunos Roadster, 1989, first 1000 ever produced.
  5. Re: turbo adapter clip hose no tight....
    Sep 2009
    Broxburn
    The smoking is due to the engine fuel being metered by the air being sucked into the turbo not in balance with what is being injected to the engine as boost is escaping resulting in the combustion being overfuelled... and lots of smoke. Get it sealed up and it should be okay
  6. Re: turbo adapter clip hose no tight....
    Jan 2014
    london
    Today I change the whole turbo pressure hose
    And I seal it up with this
    I even change the MAF too
    I pute this engine cleaner to clean the carbon build up
    And I went for a 20 miles hard drive on the motorway
    engine and turbo sound really better with some power improvement.
    At driving car smoke fare less and no more iddle issue
    on motoway no smoking at all but as soon I park in my drive and reversing there is some smoke come out .
    there is my question what possibly can cause the smoke ?
  7. Re: turbo adapter clip hose no tight....
    Apr 2017
    Neverland
    7 Post(s)
    Quote Originally Posted by Master Sylvain View Post
    Did the RTV Silicone hold up at the charge air hose? Did you put it on the turbo outlet side, or on the other side, where it connects to the hose going to the intercooler?
  1. Question Radiator Hose Clip
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2012, 06:56 PM
  2. Question How do i fit this clip on this hose ?
    By Adjani in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 06-07-2008, 10:37 PM
  3. Where can I get a spring clip for the radiator bottom hose ?
    By JonE in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-08-2007, 04:21 AM
  4. Water hose clip for 1994 audi 90 coupe
    By lexxb88 in forum 80 - 90
    Last Post: 03-07-2007, 12:10 AM
  5. Water hose clip for 1994 audi 90 coupe
    By lexxb88 in forum Archive posts
    Last Post: 02-07-2007, 07:40 PM
