Thread: 1.9 TDi ASR light and misfire/juddering
Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
  1. Re: 1.9 TDi ASR light and misfire/juddering
    Jun 2014
    Reigate, Surrey
    Mine got progressively worse over time... If yours does become more frequent, eventually never going away - could be another faulty loom.
  2. Re: 1.9 TDi ASR light and misfire/juddering
    Aug 2017
    Farnham England
    Had the same problem with my 03 MK4 golf TDI. Misfiring for first 15 minutes, ESP light on, turn engine off then on would reset it. Cleaned the EGR valve out, very cruddy, still the same. Went for injector loom, 76 from VW main dealer, took an hour to replace, make sure you change the rocker gasket, 12 from GSF. Now all fixed, runs sweet as a nut, better than before. Hope this helps.
  3. Re: 1.9 TDi ASR light and misfire/juddering
    Sep 2019
    Shrewsbury
    Hi, appreciate this is an old message but my Bora 1.9 TDI has just started doing this. I have tried my OBDII scanner but it doesn't register any codes for this problem despite the ASR light being on.
    I have ordered a replacement loom and rocker cover gasket to replace and will also remove and clean the EGR valve at the same time ready for the winter.
  1. Replies: 128
    Last Post: 11-05-2015, 11:06 AM
  2. Please Help 2002 tdi juddering / misfire
    By pauldonjuan in forum Golf MK4 - 1999 - 2004
    Last Post: 10-12-2013, 02:19 PM
  3. Replies: 4
    Last Post: 30-01-2013, 08:42 PM
  4. 2002 Tdi 130 Juddering / Misfire
    By groovyg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 05-01-2011, 05:04 PM
  5. VW Golf gt tdi 115 ASR light & ABS light
    By wez326 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 23-01-2007, 02:25 PM
