Thread: Replaced Window Regulator...Door Not Shutting Properly :( Window Cracked!
  1. Replaced Window Regulator...Door Not Shutting Properly :( Window Cracked!
    Mar 2007
    I changed my driver's side window regulator yesterday...followed this video which I thought was an excellent guide...Audi Window Regulator Replacement (A4) FCP Euro - YouTube
    Anyway...it was raining all day and clearly someone before me had been at the regulator as one of the bolts was rounded to hell which took a good hour or so to deal with. After 6 hours...yes 6 hours...I got it all back together and it works brilliantly. HOWEVER...the driver's door now seems like its out of alignment as it needs a heftier shove to get it shut and its clearly under some pressure when it is released. The door frame all lined up fine when put back together, all the bolt holes married up so I am not sure what's causing it. THEN...this morning I find the windscreen has a crack on it from the bottom of the driver's side corner going diagonally for about 7 or 8 inches!!! What have I done???! Please help...
  2. Re: Replaced Window Regulator...Door Not Shutting Properly :( Window Cracked!
    Aug 2016
    Swindon
    Not sure if this is of any help, as I am quoting from experience with an A3, not an A4.
    But when you put the window frame back in, is there a bolt hole which is adjustable? which comes out from the frame itself to align the frame and the door?
    Might be worth having a look to see if this is adjusted out too far.
    As I said, my experience is from an A3, just thought I would chime in, just in case it may help
  3. Re: Replaced Window Regulator...Door Not Shutting Properly :( Window Cracked!
    Pembrokeshire
    22 Post(s)
    just over 2 years too late. i think the poor chap actually ended up setting fire to it in the end.
  4. Re: Replaced Window Regulator...Door Not Shutting Properly :( Window Cracked!
    Aug 2016
    Swindon
    Sorry - I am new to the forum
  1. 2003 Drivers door window regulator
    By neovw in forum Passat - B5 Forum - 1997 -2005
    Last Post: 01-06-2011, 09:53 PM
  2. Wanted ! Manual window regulator for 3 door drivers door!
    By m0mjt in forum Golf MK4 - 1999 - 2004
    Last Post: 23-04-2010, 10:56 AM
  3. A4 Cabriolet - Window not closing fully after shutting door - Ice
    By tag2312 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-01-2010, 10:13 AM
  4. Driver's door window regulator motor
    By andyapanel in forum Golf MK3 - 1993 - 1999
    Last Post: 12-10-2008, 09:47 AM
  5. Polo Electric Window Regulator V Plate 3 Door
    By sparkplug01 in forum Polo - Derby - Lupo - Fox
    Last Post: 27-05-2008, 12:39 PM
