Thread: U281 Diagnostic Result
  1. U281 Diagnostic Result
    Jun 2014
    Bedford, United Kingdom
    Hi, I have just joined and seriously don't know a lot about cars, so please be nice! I got hold of a U281 Memoscanner as my airbag light has come on. My car is a VW Golf 1.6SE 1999 Petrol. I followed the instructions and this is code that came up:
    Please can anyone tell me what I need to do to fix this? I've read a few things about connectors under seats, etc. As I said before, I am pretty rubbish when it comes to car stuff, but I'm a quick learner! Pictures or videos of how to fix this would be great!
  2. Re: U281 Diagnostic Result
    46 Post(s)
    Googling that number brings up;
    Possible Symptoms
    Malfunction Indicator Lamp (MIL) active
    Possible Causes
    Wiring/Connectors from/to Side Airbag Igniter, Front Driver Side (N199) faulty
    Possible Solutions
    Check Wiring/Connectors from/to Side Airbag Igniter, Front Driver Side (N199)
    Check Side Airbag Igniter, Front Driver Side (N199) faulty
    Check Measuring Value Blocks (MVB)
    Special Notes
    When found in the NAR '05 -> '07 Jetta, Rabbit, Eos and Passat, Please See TSB 69-08-02 / 2011271.
    When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
  3. Re: U281 Diagnostic Result
    Jun 2014
    Thanks A6_Chris, have you fixed this fault before? Any help with exactly what to do would be great!
  4. Re: U281 Diagnostic Result
    46 Post(s)
    Not had experience of it, all the info you need is shown above.
  1. U281 Diagnostic Tool
    By Ianboom in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 04-12-2014, 11:38 PM
  2. A Right Result
    By DSG4ME in forum Chat - Completely Off Topic
    Last Post: 29-01-2014, 02:52 AM
  3. Result!
    By M1tchy in forum A7 - S7
    Last Post: 14-10-2013, 06:52 PM
  4. U281 Handheld Fault Code Reader
    By matmcn in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 11-03-2009, 12:40 AM
  5. Result!
    By k9max in forum Chat - Anything with wheels
    Last Post: 22-09-2008, 01:34 PM
