Thread: 55 2.0 tdi juddering issue
Results 1 to 10 of 15
  1. 55 2.0 tdi juddering issue
    Romark2001 Guest
    Hi all, just looking for a bit of advice really on an issue that has started in the last week or so with my 55 2.0 tdi.
    Seems to be a problem in the morning whereby for the first 15 miles or so if I put my foot down e.g. joining a motorway or overtaking the car will judder like it wants to stall. After the first 15 everything seems to be fine. Car has now done about 55,000 miles.
    I haven't had any other engine problems apart from last year when it went into the "get home" mode at a remote part of the Scottish highlands (an interesting experience) and had a software update.
    Any ideas?
  2. Re: 55 2.0 tdi juddering issue
    Romark2001 Guest
    Further to the above I experimented a bit on the commute to work last night and this morning and it does not seem limited to time of day or length of time running......problem seems to occur when the rpm exceeds 3000. Feels a bit like the fuel flow isn't what it should be possibly clutch?
  3. Re: 55 2.0 tdi juddering issue
    Sounds like a fault with the air mass flow meter.
  4. Re: 55 2.0 tdi juddering issue
    Romark2001 Guest
    Thanks for your reply Thatch. Got it booked in to be looked at!!
  5. Re: 55 2.0 tdi juddering issue
    Aug 2007
    Had the same today! Only got to the point were it wouldn't re start. Have had it towed to VW tonight. RAC man thought it could be something blocking the exhaust.... Not so sure myself.
    Will report back when VW have had a look.
  6. Re: 55 2.0 tdi juddering issue
    May 2007
    knee deep in clunge
    14 Post(s)
    air mass faults are pretty few and far between on 2.0 tdi engine but egr valve is common and the flap can break away causing this symptom.
  7. Re: 55 2.0 tdi juddering issue
    Romark2001 Guest
    Well God bless it it has made it through the week! On the commute home last night the fault did not occur but this morning my joining the motorway must have looked like a sack of spuds being rolled down a cobble street.
    Will post what VW say tomorrow just in case there are others with similar symptoms in the future.
  8. Re: 55 2.0 tdi juddering issue
    Romark2001 Guest
    Well car was in on Friday and the verdict is......
    Blocked fuel filter (apparently VW don't change the filter on normal service and due to decrease in fuel quality this is causing a problem in a lot of cases)
    Having changed this they found that the fuel pump wasn't 100% so this was also changed. Now it runs as sweet as the day I got it.
    Thanks to all those that replied to my initial post.
  9. Re: 55 2.0 tdi juddering issue
    Apr 2007
    France
    12 Post(s)
    Read all this with interest, and it's worth bearing in mind. Thanks for the follow-up!
  10. Re: 55 2.0 tdi juddering issue
    Aug 2007
    Picked mine up this afternoon after leaving it a week with the ******* . Needed a new fuel pump.
  1. Juddering on overrun
    By Fourbears in forum Passat - B5 Forum - 1997 -2005
    Last Post: 10-09-2007, 09:39 PM
  2. Juddering wipers
    By Dave Elcome in forum Passat - Archive Topics
    Last Post: 08-06-2007, 10:51 PM
  3. juddering issue
    By carl_townshend in forum Passat - B5 Forum - 1997 -2005
    Last Post: 07-06-2007, 09:04 PM
  4. Juddering S4
    By Lenny75 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 10-04-2007, 06:28 PM
  5. Juddering C
    By JBOB in forum Scirocco - Corrado
    Last Post: 13-06-2005, 06:00 PM
