Thread: Query alternator woes, second opinion please - Battery light, alternator
  1. Angry Query alternator woes, second opinion please - Battery light, alternator
    Evening All
    1.9tdi 182K
    Im getting the intermittent battery light, on/ off, then on solid then off etc
    At the start of the year I replaced the battery, then got the alternator refurbed and changed the clutch pulley.
    Now this again
    Changed the belts, checked and cleaned all connections, tensioners are fine..............................
    At idle 14 V
    Under load 13.5V ( AC, fogs, rear demist, headlights)
    Then for no reason the light will come on and the volts drop away till it gets to about 10V and stays there
    Its the same at the battery as the alternator
    Wiggling wires has no effect whatsoever so Im thinking Alternator is FUBAR
    You can really begin to hate a car
    Answers on a post card please
  2. Re: Query alternator woes, second opinion please - Battery light, alternator
    Dec 2007
    8 Post(s)
    It may be the regulator/ brush pack which is simple to replace.
    If the repair was only recent,why not look to have it repaired under warrantly.
    Also enter gav10 in search box. Similar problem post, but short in wires blew new regulator!!!
    I have come across a problem where the main terminal on altenator appeared to be good,but on closer inspection
    the nut was tightening the insulation of cable tighter to the body,but the actual terminal was not making good contact.
    You seem to have ruled this out if all connections were cleaned up,but it may help someone. (In this case the voltage was reducing intermittently until cleaned and tightened)
  3. Re: Query alternator woes, second opinion please - Battery light, alternator
    Cheers for the reply
    Yes I had a look at his problems as well. Im working on the principle that as its giving the same readings at the alternator (+ve / outer casing of alt) it cant be a wiring fault?
    I will whip it off and take it back to the alternator Doctor and see what he says
  4. Re: Query alternator woes, second opinion please - Battery light, alternator
    Dec 2009
    Waterlooville U.K.
    13 Post(s)
    You should get 14V + under load.
    Skoda Octavia II SE 1.9PD TDI
  1. 2002. POLO 1.9TDI. Alternator Fault and no battery light on dash.
    By prestigej in forum Polo - Derby - Lupo - Fox
    Last Post: 08-06-2021, 08:11 AM
  2. Please Help t5 battery light on alternator???problem or quick fix?
    By cashcrash in forum The Commercial Range
    Last Post: 28-08-2018, 07:08 PM
  3. Faulty alternator without battery warning light???
    By M3 Compact in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 16-07-2010, 07:51 PM
  4. Replies: 6
    Last Post: 11-12-2008, 07:16 PM
  5. Question Alternator workshop and Battery light
    By noddy1875 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 04-08-2008, 02:58 PM
