Thread: boost questions / n75 issue?
  1. boost questions / n75 issue?
    Apr 2014
    Hi guys bit of advice/help needed got a vento 1.9tdi AHU engine code, my question is about boost what is standard boost pressure? Mine is boosting up to 18psi first and second, then in third it hits 18psi then drops to 13psi very suddenly, so what's going off guessing something is not right? The only mod so far is decat. Only just fitted boost gauge today so only just seeing the issue if there is one, I would like to remove the n75 valve and fit a manual boost controller, and bleed valve in between ecu and boost pressure to fool ecu to make its still boosting but lower down is it possible?
    Thanks in advance
  2. Re: boost questions / n75 issue?
    Up North
    Does the car drive okay? If so, leave it alone and stop having grand plans to blow your engine up.
    Driving - Shiny new E350 Estate.. Just Arrived - Aggh! a C-Max. What have I done?
    Just Gone - 2008 Passat 2.0CR TDi DSG Estate + toys, 2007 Golf GTI
    Once, cars were simple and I was smart. Now things are the other way around.
  1. No boost and low voltage to N75
    By gmac78 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 26-01-2013, 11:25 PM
  2. N75 Boost Valve Issue A6
    By bag320 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 31-10-2011, 01:33 PM
  3. n75/EGR and Lack of Boost
    By carspark in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 24-01-2011, 02:10 PM
  4. N75 - Boost Control Solenoid
    By twign in forum Golf MK4 - 1999 - 2004
    Last Post: 05-06-2008, 08:56 AM
  5. Loss of boost? N75 or MAF??
    By gonie in forum Chat - Anything with wheels
    Last Post: 02-05-2008, 08:10 PM
