Thread: Difference between soot measured and soot calculated?
  1. Difference between soot measured and soot calculated?
    Oct 2010
    Huddersfield
    Does anyone know the answer to this in regards to dpf regeneration and vcds? On a hard run the measured goes down quite quickly. But calculated takes ages to move.
    Is it just the measured I should be interested in for dpf runs?
    Sent from my GT-I9505 using Tapatalk
  2. Re: Difference between soot measured and soot calculated?
    Oct 2010
    Huddersfield
    No one?
  3. Re: Difference between soot measured and soot calculated?
    Oct 2010
    Huddersfield
    Still no one? Thought it would be a quick easy answer for those in the know!
  4. Re: Difference between soot measured and soot calculated?
    Oct 2010
    Huddersfield
    Still can't believe no one knows the answer to this!
  5. Re: Difference between soot measured and soot calculated?
    Aug 2014
    Boston
    Hi. I asked similar question on A5 forum and answer was "Is the soot mass calculated what you could have since the last regen whereas the measured soot mass is what is actually present?"
    -Magic
    A5 S-Line 3.0TDi Quattro Stronic May2010
  1. Question Soot after DPF removal.
    By mark wade in forum Golf MK5 - 2004 - 2009
    Last Post: 25-06-2013, 11:38 AM
  2. Please Help black soot
    By phase4 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 31-07-2010, 09:40 PM
  3. oil and soot on glow plugs
    By brighton123 in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 16-05-2008, 08:10 PM
  4. 98 A4 1.9Tdi - smoke,soot & intermittent turbo
    By Phil247 in forum Audi A4 - Archive Topics
    Last Post: 11-02-2008, 11:28 PM
  5. What Diesel do you use in your soot chucker?
    By Fizzbitt in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 06-07-2007, 08:38 AM
