Thread: Vcds near guildford
Results 1 to 10 of 14
  1. Vcds near guildford
    Apr 2014
    Hi does any one have Vcds near guildford many thanks
  2. Re: Vcds near guildford
    Southern County Softy
    20 Post(s)
    Bracknell near enough.
    Sent from my GT-I9505 using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: Vcds near guildford
    Feb 2014
    Weybridge
    Using Tapatalk
  4. Re: Vcds near guildford
    Nov 2010
    Guildford, UK
    I need some help please. Have a mk5 golf gt. The auto lights stayed on after parking the car and drained the battery recently. Seem to be working again, but I don't trust them now so need to scan. Possible CECM module fault.
    Also need to change the brake fluid and exercise abs using vids. Would be good to do both jobs at same time which would mean car at mine in Guildford on stands. But if that doesn't work for anyone then I could travel and Ignore the abs exercise as a part of fluid change. Tokens obviously to compensate travel etc.
    thanks
    Andy_D
  5. Re: Vcds near guildford
    Feb 2014
    Andy, I could assist. I don't know the procedure for the bleeding etc but if you can find out how to do it I could assist. Well give you the laptop and you can click enter! Ha ha
    Using Tapatalk
  6. Re: Vcds near guildford
    Feb 2014
    Can you do during daytime?
    Using Tapatalk
  7. Re: Vcds near guildford
    Nov 2010
    Guildford, UK
    Hello gtime. Sorry been camping so no internet and phone mostly off to preserve battery. Back on deck now. Yes, can do most day times. Fault read is most important thing but if you were going to the trouble of getting here, I should put the car on stands and run the abs cycle procedure. I'm familiar with how to bleed - I've never used vcds to cycle the abs but I'm sure we would find the option with the help of googling.
    Think I need 10 posts to receive PMs so we can reply to and fro a couple of times or I can post my email up for little while then remove it. Open to when would work for you.
  8. Vcds near guildford
    Feb 2014
    Hi Andy, no worries. I might be able to do this Thursday if any good for you?
    Using Tapatalk
  9. Re: Vcds near guildford
    Nov 2010
    Guildford, UK
    Got it thanks. Thursday could be good. Maybe remove your email address now so no spammers. I meant I would put mine up in the thread and risk it, but v good of you to do so. Think I have 10 posts now so maybe I can actually receive PMs now but will send you an email direct anyway. Thanks again.
  10. Re: Vcds near guildford
    Feb 2014
    No worries, I will remove it now. Not had problems before but better to be safe.
    Using Tapatalk
  1. Great Indie In Guildford
    By as400 in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 10-01-2013, 03:24 PM
  2. No Rice in Guildford
    By greenphotos in forum Shows & Events
    Last Post: 04-09-2008, 08:16 PM
  3. Colbornes bodyshop, Guildford
    By Adam Sothcott in forum Reviews & Recommendations of Dealers & Independant Garages
    Last Post: 21-08-2008, 07:19 AM
  4. NO RICE 12/9/07 Guildford
    By v6dub in forum Shows & Events
    Last Post: 13-09-2007, 11:20 PM
  5. Hello! Golf Cabby from Guildford...
    By Phil K in forum New Member Introductions
    Last Post: 04-05-2007, 12:34 AM
