Thread: Audi A4 B8 Saloon Front Door Control Module Part Nos for Folding Mirrors
  1. Audi A4 B8 Saloon Front Door Control Module Part Nos for Folding Mirrors
    Dec 2009
    Lincoln
    Hi there
    My son and I both have 2011 Audi A4 2.0 TDi 170s S-Line Black Editions; his is a saloon and mine an Avant. We both have had folding mirrors fitted professionally and my Avant exhibits no VCDS fault codes as a result. The new front door control modules fitted to mine have part numbers 8K0 959 793 M and 792 M (both SW & HW).
    His saloon is now fitted with door control modules with part numbers 8T0 959 793 G and 792 G (SW & HW) and these give a ‘03175 – Invalid Data Set error’ in VCDS (full hardware version, software 12.12.2.0). Although I though 8T0 modules were for an A5, the difference in part number makes sense as the original front modules on his were 8T0 as are the rears so this is obviously something they did to the A4 saloon.
    I have asked Audi to reset the car to default using VAS (although I got the feeling that they had little idea what they were doing) and then I recoded the modules correctly for the folding option and the MMI auto-fold menu item. They work fine now (as they did before) but it annoys me nevertheless.
    Audi will not check part numbers for me so I would be really grateful if anyone could confirm the correct front door control module part numbers for a 2011 (pre-facelift) Audi A4 saloon fitted with folding, heated but not dimming door mirrors. I can give you the VIN number if you need it.
    Many thanks!
  2. Re: Audi A4 B8 Saloon Front Door Control Module Part Nos for Folding Mirrors
    46 Post(s)
    Did you look on Rosstechs site for the code?
    03175 - Ross-Tech Wiki
    Says basically there is currently no solution.
  3. Re: Audi A4 B8 Saloon Front Door Control Module Part Nos for Folding Mirrors
    Dec 2009
    Lincoln
    Hi Chris
    Many thanks for your prompt reply.
    Yes, I saw the Wiki and if both cars had the same fault then I wouldn’t be concerned. It’s just confusing that mine does not have any fault codes and thus there is the faint possibility that my son’s car has had incorrect modules fitted (although the company that fitted them have a decent reputation).
    Someone gave me a link to an online ETKA and that listed a module with the part number 8T0 959 793 M, not G (and note that my new modules end in ‘M’) and that is why I wondered if anyone could confirm the correct part numbers for my son’s car with its new modifications.
  4. Re: Audi A4 B8 Saloon Front Door Control Module Part Nos for Folding Mirrors
    Mar 2011
    world
    Removing fault VCDS 03175 "Invalid Data Set"
    In the carmenuoperation menu i added 1 to every option then rebooted
    go into the hidden menu
    - go to car -- carmenuoperation
    - change every value by adding "1"
    - restart the MMI
    - go into the hidden menu again
    - change the values back to their original value, i.e. substract "1"
    - restart the MMI
  1. Folding/Heated Door Mirrors Part Numbers Please
    By Owendavies in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-10-2013, 11:45 AM
  2. Please Help Part numbers for folding door mirrors A8Tech/Crasher
    By phil miller in forum Golf MK5 - 2004 - 2009
    Last Post: 19-02-2012, 10:55 AM
  3. A5 folding door mirrors
    By j_ritchie in forum Audi A5 - B8 Forum - 2007 - 2016
    Last Post: 23-02-2010, 07:44 PM
  4. Help/advice please - climate control unit part nos.
    By BTB 500 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 18-11-2009, 03:45 PM
  5. RS6 Folding door mirrors
    By Noginthenog in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 26-05-2009, 05:32 PM
