Thread: Help :( white smoke misfire/judder idle
Results 1 to 10 of 10
  1. Help :( white smoke misfire/judder idle
    Apr 2014
    Essex
    my 3.0tdi 05 a8 has developed a heavey misfire/judder on idle if you rev is you can clear it and it smokes badly also (white) everything lead to injectors .
    I've recently changed injectors myself coded ect via vag com but still no joy no fault codes
    Only think I have noticed since I changed em is that group 72-77 won't give me any sort of reading ..... I.e all sit on 0.0 does this mean I've done something wrong ?
    Group 13-14 still give me a reading
    I just want to fix this now as it's starting to cost me a few ££££££ and only owned it 3 weeks
    Any ideas what elce it could be as the injectors where removed from a fully working car any help would be great cheers Scott
  2. Re: Help :( white smoke misfire/judder idle
    Jun 2006
    UK, Mids
    If you code the injectors, then they go to 0.0 (factory calibrated) so that is normal and they then adapt over time as they wear.
    Did you use new injectors? re-adpting old ones back to zero would cause this.
    Audi A8 - 2015 - 3.0TDI
  3. Re: Help :( white smoke misfire/judder idle
    Apr 2014
    Essex
    No these where good used ones mate only other thing I've noticed is that cyl 6 in at like 5.02 and cyl 4/5 are around 0.43 roughly . Although it don't matter what injector goes in 6 it always runs like that . I'll get proper read outs of 13-14 today and post em up
  4. Re: Help :( white smoke misfire/judder idle
    Jun 2006
    UK, Mids
    That could be the problem. The codes printed on the injectors are the factory calibrations - if you fit used ones and then revert back to the factory calibrations after they have been used for a number of years then they will be out.
    Could it be a lack of compression? Did the car develop this while you had it or did you buy it like this?
  5. Re: Help :( white smoke misfire/judder idle
    Apr 2014
    Essex
    Car developed this about a week ago I bought it after doin all the checks ect that I found for common problems but guessing I didn't check good enough .
    So does this mean that the second hand injectors a rendered useless then ? Or can they be adjusted manually ? Cheers Scott
  6. Re: Help :( white smoke misfire/judder idle
    Apr 2014
    Essex
    On idle values 13/14
    -1.84
    0.05
    -3.20
    0.14
    -0.61
    5.04
    Thats cylinders in order :/
    Sent from my GT-I9100 using Tapatalk
  7. Re: Help :( white smoke misfire/judder idle
    Apr 2014
    Essex
    Ok update whilst the car is running in you remove the swirl flap arm and manually open then the car runs fine ?
  8. Re: Help :( white smoke misfire/judder idle
    Jul 2011
    newmarket
    Try unplug coolant temp sensor or fuel temp sensor while car is running, if misfire stop then injectors gone.
  9. Re: Help :( white smoke misfire/judder idle
    Jun 2006
    UK, Mids
    It might be worth searching for threads by gupsterg - he had similar trouble with his A6 which may be useful.
  10. Re: Help :( white smoke misfire/judder idle
    Apr 2014
    Essex
    I've replaced temp sensor but will try fuel temp today . Just to note its only on bank 2 if you manually open it runs fine on bank one it makes no difference runs the same open/closed
  1. Blue/White Smoke on startup and idle everytime
    By Imizz in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 06-09-2014, 11:12 AM
  2. 2.0 tdi bmn / bkd engine idle misfire/judder PLEASE HELP!!!
    By GTRUSS in forum Golf MK5 - 2004 - 2009
    Last Post: 09-09-2012, 04:34 PM
  3. Please Help gti tdi 150bhp idle judder and low throttle judder
    By rs250gpracer in forum Golf MK4 - 1999 - 2004
    Last Post: 16-02-2010, 10:42 AM
  4. Irratic Idle,white Smoke Now No Start Passat Tdi 97
    By craigdix in forum Early Passat Forum - Pre 97
    Last Post: 06-02-2009, 12:53 AM
  5. A3 2.0TDi Idle / Misfire and Smoke Problem
    By MartinA3 in forum Audi A3 - Archive Topics
    Last Post: 12-08-2008, 05:08 PM
