Thread: Help with codes
  1. Help with codes
    Mar 2013
    Gateshead
    Please can you help me with these codes,This is what came up, charge presure control negatative deviation : P1556
    Profit is Vanity, Quality is Sanity
  2. Re: Help with codes
    vacuum leak . on one of the small black pipes
  3. Re: Help with codes
    Mar 2013
    Gateshead
    I changed the vacuum pipes yesterday with new pipes while doing that i found a split hose which may be the problem as the hose gos the bottom turbo to the front of the car I think it is to do with airflow to the turbo not sure.
  4. Re: Help with codes
    sounds like the n75 valve pipes.
  5. Re: Help with codes
    Mar 2013
    Gateshead
    Late update but better late than never after all it was Easter weekend, I replaced the s shaped hose with the two metal things at each end it was a brand new one for which I was quoted £180 over the phone but with a bit hum and har i managed to get it for £93 still I thought that was pricey anyway the result was good and all is well my Passat 130 sport is as it should be.
    Thanks to passat 130 tdi for your replys to my post.
  6. Re: Help with codes
    No bother I'm in seaham if ever you need a code scan
  7. Re: Help with codes
    Mar 2013
    Gateshead
    Thanks passat 130 tdi, I have one of those Vag code readers.
  1. GU, RH etc. codes
    By davidcoxell in forum Golf MK2 - 1984 - 1992
    Last Post: 28-10-2009, 05:50 PM
  2. Codes
    By DSW in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-09-2009, 12:25 PM
  3. codes
    By r34 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 10-09-2008, 03:37 PM
  4. Codes????
    By Alun in forum Chat - Anything with wheels
    Last Post: 03-04-2007, 05:54 PM
