Thread: Auto Gearbox Problem.
Results 1 to 10 of 15
  1. Auto Gearbox Problem P178F code
    Dublin, Ireland
    This happened me last night when it was in reverse, drove maybe 200 yds in R.
    Got the error on dash that I can drive with limited function. Car would only drive at 10 mph.
    So stopped and restarted car again, fault now saying that I can drive. Driving ok again but these are the faults I got.
    2 Faults Found:
    005955 - Clutch Slip Monitoring
    P1743 - 000 - Signal too Large - Intermittent
    Freeze Frame:
    Fault Status: 00110000
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 237911 km
    Time Indication: 0
    Date: 2014.04.06
    Time: 20:00:48
    Freeze Frame:
    RPM: 2784 /min
    RPM: 220 /min
    (no units): 31.0
    Torque: 40.0 Nm
    Temperature: 74.0°C
    T.B. Angle: 24.4°
    Bin. Bits: 0110 0 0
    006031 - Pressure Regulation Valve
    P178F - 000 - Dirty / Clogged
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 0
    Fault Frequency: 1
    Reset counter: 255
    Mileage: 237911 km
    Time Indication: 0
    Date: 2014.04.06
    Time: 20:01:09
    Freeze Frame:
    RPM: 864 /min
    RPM: 70 /min
    (no units): 21.0
    Torque: 2.0 Nm
    Temperature: 76.0°C
    T.B. Angle: 55.6°
    Bin. Bits: 0110 0 0
    Address 02: Auto Trans Labels: 01J-927-156.lbl
    Control Module Part Number: 4F5 910 157 F HW: 01J 927 156 JG
    Component and/or Version: V30 01J 2.0l CR RdW 0010
    Software Coding: 0000001
    Work Shop Code: WSC 02325 785 00200
    VCID: 2C5CF4368F891B7E17F-8079
    I Cleared the faults and drove car for a while and rescanned again and got this fault now
    1 Fault Found:
    Freeze Frame:
    Fault Priority: 0
    Fault Frequency: 3
    Reset counter: 255
    Mileage: 237943 km
    Time Indication: 0
    Date: 2014.04.06
    Time: 21:08:28
    Freeze Frame:
    RPM: 96 /min
    RPM: 0 /min
    (no units): 1.0
    Torque: -30.0 Nm
    Temperature: 70.0°C
    T.B. Angle: 0.0°
    Bin. Bits: 0101 0 0
    The fault will not clear and the light comes on when ignition is switched on.
    Any ideas before I bring It to Audi ?
    A6 2.0 tdi Auto 2008 Facelift.
  2. Re: Auto Gearbox Problem.
    46 Post(s)
    When was the fluid and filter last changed?
    Make sure your VCDS is running 12.12.2 too.
  3. Re: Auto Gearbox Problem.
    Dublin, Ireland
    About 50K miles Chris.
  4. Re: Auto Gearbox Problem.
    46 Post(s)
    50k ago? If so it's 12k overdue a change.
  5. Re: Auto Gearbox Problem.
    Dublin, Ireland
    Was looking at a how to, but noticed my gearbox LDQ looks different. No bottom square plate. Will get a proper look tomorrow as it was raining today. Thanks
  6. Re: Auto Gearbox Problem.
    46 Post(s)
    Get a specialist to do it.
    Don't confuse your gearbox with tiptronic as your car isn't quattro!!
  7. Re: Auto Gearbox Problem.
    Dublin, Ireland
    Will do so, Thanks again.
  8. Re: Auto Gearbox Problem.
    Dublin, Ireland
    Got the car looked at by 7th gear in Dublin. Gearbox seems ok, they are taking the ecu out and going to go through it. Leaving it back on Monday for them to do an oil change & ecu repair.
    The same fault happened again when he went into reverse and drove it a bit hard,
    Will let you know the outcome, next week.
  9. Re: Auto Gearbox Problem.
    Dublin, Ireland
    Just an update, got the oil changed. He had a look at the ecu and said that it was perfect. He would have to open up the gearbox to see if he could see anything wrong, but said that it was driving perfect except for the hard driving in reverse. He advised to keep driving until something went really wrong, but couldn't understand why he couldn't clear the fault as he never came across this. Might get a second opinion on it in a few weeks time.
    Will update when I get more info.
  10. Re: Auto Gearbox Problem.
    Dublin, Ireland
    Since the oil has been changed, this fault hasn't returned. Although I never took to driving hard in reverse.
    I got onto Ross Tech for some info on clearing the Fault as VCDS wont clear it. Here is the reply just in case anyone gets the fault.
    With the P178F code, the factory documentation shows to replace the
    Mechatronic Unit. What little I do find on this specific fault code
    seems to imply that "extended oil services" can cause this. Having said
    that... CVT Mechatronic Units fail often anyway.
    Note that when a new Mechatronic Unit is installed, the dealer may have
    to match it to the vehicle. You might get a "Locked" type fault code in
    the TCM and the car may not move under its own power. 2007 and newer
    Audi vehicles might run into this.
  1. a4 auto gearbox problem
    By knight in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-06-2009, 01:48 PM
  2. a4 auto gearbox problem
    By knight in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 09-06-2009, 01:46 PM
  3. Please Help Auto gearbox problem
    By stephennunn in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 07-11-2008, 11:18 PM
  4. auto gearbox problem
    By danglee in forum New Member Introductions
    Last Post: 12-06-2008, 07:52 PM
  5. 1.8 auto gearbox problem
    By hocks172 in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 17-02-2008, 01:33 PM
