Thread: Security Question
Results 1 to 10 of 11
  1. Security Question
    Apr 2013
    Yorkshire
    Hi All
    I will be going on holiday soon and my car ( A4 Avant MY12 2.0 TDi Tech pack) will be sat on the drive for 2 weeks, i was thinking how safe it will be, I live on a nice estate bit know is not people near me that will steal it. Any ideason how to secure it ?
    How good is the imoboliser ?
    Thanks Shaun
  2. Re: Security Question
    Feb 2013
    Gloucester
    57 Post(s)
    It will be fine, a modern car cannot be started without the keys. Either take both Keys with you or put them in a safe in your house.
    If you have an old iPhone or iPad put it in your car and activate find my friends then you can track your car too for piece of mind. I've got an old iPhone in mine hidden away with constant power so if it did get stolen, I can track it.
    Sent from my iPad using Tapatalk HD
  3. Re: Security Question
    Jul 2008
    Essex, United Kingdom
    As above...keep the keys safe and the car should be safe. If you really are worried, you also can't beat an old-fashioned steering wheel lock...they are cheap, easy to install/remove and make the car 10x harder to steal.
    -Andrew
    1994 VW Polo 1.4L (Scrapped)
    1998 VW Polo 1.4L - Somewhere Out there...
    2004 Audi A4 1.9TD 130bhp <--Gone but not forgotten!
    2011 Audi A4 3.0 V6 TDi 240bhp - Moved on, but still going
    2017 Audi S3 2.0 TFSI 310bhp
  4. Re: Security Question
    Pembrokeshire
    22 Post(s)
    try to park in a tight space up against your house if you can and put the steering on full lock, makes it harder to drag it out. also ask a neighbour to use your drive to make it look occupied and then they will nick their car rather than yours.
  5. Re: Security Question
    Oct 2005
    As said above, it cannot be driven without the keys. Unfortunately that means any would-be thief is going to be turning your house over looking for said keys.
    I'll go on holiday for you while you stay and look after your car if you want?
  6. Re: Security Question
    46 Post(s)
    Unfortunately after the spate of BMW's being stolen via keys programmed via the OBD port, Audi's aren't that safe either!
    Keyless entry - Gone in 90 seconds
  7. Re: Security Question
    Dec 2012
    Gwent
    Not just keyless entry. An old colleague had his A4 nicked off his drive, driver window smashed and new key programmed via OBD port (West Midlands). Coppers told him it was getting worryingly common
  8. Re: Security Question
    Jul 2008
    Cough cough. *steering wheel lock* cough.
  9. Re: Security Question
    Nov 2012
    Lincolnshire
    Quote Originally Posted by theskyfox View Post
    Decent bolt croppers would take less than a minute to chop the wheel, no problem.
    J
  10. Re: Security Question
    Aug 2012
    Hampshire
    This is why I have had relocated my obd port to another position.
    I know that pros could then climb in, feel around under the trim, find the cable and it trace it back to the port, but does mean they cant just smash reach in and done.
    2013 A6 2.0TDi S-line
    Fully registered VCDS in Portsmouth & surrounding areas & fault diagnostics/resets on most other makes.
  1. Security problem
    By penrecon in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 28-06-2010, 09:47 PM
  2. Please Help your security needs you!!!
    By size12 in forum Chat - Completely Off Topic
    Last Post: 13-03-2010, 04:21 PM
  3. Question Screwdriver Security.........
    By Pudz in forum Polo - Derby - Lupo - Fox
    Last Post: 18-01-2010, 05:12 PM
  4. security question
    By tr85858 in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 02-06-2007, 01:27 PM
  5. Passat Security
    By Brian_M in forum Passat - Archive Topics
    Last Post: 12-02-2007, 11:38 AM
