Thread: Vacumm Air Leak
Results 1 to 8 of 8
  1. Vacumm Air Leak
    Jan 2010
    southport
    Hello.
    Ive noticed when driving and i go to change gear,i hear a queit hisss(if windows are down).Its like a quieter recurc dump valve sound.
    Ive checked all vacumm hoses an cut off 1 inch to all connections to rule out leaks.
    Ive just ordered new vacumm hoses to replace them all.(green)
    The car drives well,mpg good.
    I dont have VCDS.
    Anything else worth checking out.
    Cheers.
    Graham.
    2000 2.5TDI Quattro 173,000miles, just run in...Sold
    2006 TT 3.2 Quattro 40,000miles
    2005 A6 Avant 3.0TDI Quattro
  2. Re: Vacumm Air Leak
    Nov 2008
    Cramlington,Northumberland
    20 Post(s)
    Could be a small hole in an Intercooler hose?
    Alan.
    VW T6 150 DSG Camper £££
  3. Re: Vacumm Air Leak
    Jan 2010
    southport
    Update.
    All Vac hoses have been changed including the pipe to the Vac reservoir.Ive tightened the intercooler hoses too.
    Its still making the noise..
    Would a damaged/split intercooler only make this noise when changing gear or would you here it all the time.
    It doesnt make any hissing noise when you rev the engine,just when its under load when letting off to change gear.
    Anything else to check.
    Thanks for any help.
    Graham.
  4. Re: Vacumm Air Leak
    Jan 2010
    southport
    Still doind it...
    Would a scan throw any codes..
  5. Re: Vacumm Air Leak
    Jan 2010
    southport
    Before i pay out beer tokens for a scan.Would this kind of fault produce a code??
  6. Re: Vacumm Air Leak
    Dec 2007
    8 Post(s)
    Could it be exhaust leak at flexi pipe when engine moves, one member had this problem but it was accompanied by sooty smell.
  7. Re: Vacumm Air Leak
    Jan 2010
    southport
    Deffo not exhaust leak.
    Its like a silent dump valve sound hiss when letting off the gas to change gear.Car runs good,pulls well(i think).It didnt used to be there an now it is.
  8. Re: Vacumm Air Leak
    Dec 2007
    8 Post(s)
    It seems another thing that may produce a hiss sound is the wastegate valve !!
  1. diagram needed for vacumm on 2.4 v6 2002
    By scanny1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 07-05-2012, 05:50 PM
  2. air con leak
    By vwnige in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-03-2012, 09:42 PM
  3. Replies: 28
    Last Post: 24-01-2011, 10:39 PM
  4. An air leak!!!
    By andyk383cars in forum Golf MK4 - 1999 - 2004
    Last Post: 28-09-2009, 10:06 PM
  5. Possible Air leak
    By Stylee in forum Chat - Anything with wheels
    Last Post: 22-09-2008, 10:43 PM
