Thread: Strange Vibration Under Braking
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Post Strange Vibration Under Braking
    Had this for a while now when braking at 40mph i get serious vibration from pedal and steering wheel but stops before 30mph. Discs and pads have been changed, calipers at front changed had wheel alignment done and told fine,swapped back and front wheels no difference. any suggestions appreciated
  2. Re: Strange Vibration Under Braking
    Pembrokeshire
    22 Post(s)
    a shaking like that is indicative of excessive disc run out. although the discs were replaced, was the run out checked to ensure a hub isn't distorted, a more common problem on certain golf platforms. could also be a bush or ball joint loose.
  3. Re: Strange Vibration Under Braking
    had issue on old discs and pads got them checked found to be warped so changed again and still have problem.the discs and pads are pagid not sure how good they are.about distorted hub who would check that for me(garage)? cheers
  4. Re: Strange Vibration Under Braking
    Sep 2008
    6 Post(s)
    Used to regularly get vibration on relatively new pads and discs on my old 80 Avant oil burner. Part of the trouble was the car didn't have vented discs so pad transfer was fairly common, heat spots on the discs, etc. Discs were ATE with same pads.
    Moved to Brembo kit on the A4 years ago and never had an issue, although discs are vented, etc. If calipers are new we can rule out seized brake slider bolts. I'd check for worn tie-rod or ball joints. Upper arms are fairly common. Also look at CV joints.
    2016 BMW i3 REx (25k)
    2012 A4 Allroad Quattro 2.0 TDI (55k)
    2003 A2 1.4 TDI SE (166k) sold
    2001 B5 A4 2.5 TDI Avant Quattro Sport, (173k), sold
    1995 B4 80 1.9 TDI Avant SE, (175k), sold
  5. Re: Strange Vibration Under Braking
    thanks will have a look tomorrow
  6. Re: Strange Vibration Under Braking
    Jul 2007
    Stirling - Scotland
    Had this problem on a MK4 Golf. Replaced the track rod ends and now it feels brand new again. Cheap easy fix, worth checking for play.
  7. Re: Strange Vibration Under Braking
    will do steering does have a bit play,how much are we talking for track rod ends? cheers
  8. Re: Strange Vibration Under Braking
    Jul 2011
    Norway
    Maybe sounds strange, but check the wheel bearings ! And use some force. I once found a bad wheel bearing on a problem car with similar problems, everything had been replaced but by a miracle the bad bearing had been overlooked.....
  9. Re: Strange Vibration Under Braking
    Jul 2007
    Stirling - Scotland
    2 track rod ends for a B6 will be £35 max from a motor factors. Will be about £35 each for genuine parts.
  10. Re: Strange Vibration Under Braking
    £35 for a pair sound pretty good to me but does it really matter if there not genuine parts as i just looked at an ocap part. cheers
  1. Please Help strange clicking noise when braking
    By hawheed in forum Passat - B5 Forum - 1997 -2005
    Last Post: 03-04-2014, 10:21 PM
  2. strange braking related problem!
    By nutty1 in forum Bora - 1998 - 2005
    Last Post: 04-09-2009, 01:06 AM
  3. Passat braking vibration and knocking
    By samcaravelle in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-01-2009, 08:04 AM
  4. Braking vibration but not discs.
    By Little Old Me in forum Touran - Sharan - Caravelle
    Last Post: 15-12-2008, 11:43 AM
  5. Courtesy light and vibration on braking
    By Dabj in forum Golf MK4 - 1999 - 2004
    Last Post: 28-11-2007, 10:50 PM
