Thread: RS4 Grille Fitment/Removal Guide
Results 1 to 8 of 8
  1. RS4 Grille Fitment/Removal Guide
    Oct 2012
    Moray, Scotland
    HHi All,
    I fitted my new RS4 type Grille yesterday which involved me having to remove the front bumper and the original grille. I could not find any guides online relating to the B8 and the only similar one was for an A5 which has a slightly different bumper and was not a comprehensive guide. Therefore I decided to write-up my own guide with photos for each stage. Please excuse the quality of the photos as they were taken on an iPhone.
    I purchased the grille from seller tcboverstock on eBay:
    http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=231177042447
    It cost £60.12 with £36.07 delivery which incurred a £12 custom & admin charge when it arrived in the UK from the US.
    The car involved was a 2009 S line and I cannot confirm if the SE bumper of the facelift model are the same.
    **ANY PERSONS FOLLOWING THIS GUIDE DO SO AT THEIR OWN RISK AND I TAKE NO RESPONSIBILITY FOR ANY DAMAGE ETC. CAUSED**
    The time taken to carry out this task, was around 1.5 hours, but by following this guide it may be possible to do it quicker. I am not a mechanic and the guide is written as step-by-step guide for all abilities.
    Tools needed are as follows: (these can be purchased from Halfords)
    1x Torx t27, 1x Torx t26, 1x 3/8" Ratchet, 1x 3/8" 10" Extension Bar, 1x 3/8" 10mm socket, 1 x small torch (not essential), 1x small screwdriver, and some protective matting in front of the bumper.
    STEP 1: After opening the bonnet, remove the 4 bolts on the Airflow panel indicated below, using a t26.
    STEP 2: Locate the 3 plastic bolts indicated below.
    Push down on these plastic bolts.
    STEP 3: Remove the Airflow panel by pulling towards the engine bay and lifting upwards.
    The engine bay will now look like this once the Airflow panel has been removed.
    STEP 4: On the drivers side, turn the wheel inwards and locate the two bolts on the front edge of the wheel arch, as indicated below.
    Remove these 2 bolts using a t27.
    STEP 5: Peel back the wheel arch liner and locate the bolt, indicated below, that is located just below the headlight. (Note: A small torch might be useful in locating this bolt)
    Remove this bolt using the Ratchet with the attached Extension Bar and 10mm socket.
    STEP 6: There are 5 bolts located below the bumper. Remove these using a t26. (Note: There is a bolt located on the far edges of each side of the bumper, that is indicated on the left of the photo below. These bolts are different to the other 3 bolts so make sure you don't mix these up.)
    STEP 7: On the passengers side, turn the wheel inwards and locate the two bolts on the front edge of the wheel arch (the same as what was carried out on the drivers side. Remove both of these blots using a t27.
    STEP 8: Peel back the wheel arch liner.
    Locate the bolt, as indicated below, that is located just below the headlight. (Note: A small torch might be useful in locating this bolt)
    STEP 9: Locate the two bolts on the top of the bumper, as indicated below.
    Remove these bolts using a t26.
    Use a screwdriver, lift the flange located underneath each of the two bolts. (Note: Be careful not to damage the paint of the bumper when using the screwdriver)
    STEP 10: Remove the Fog Light surrounds on either side by giving them a good pull outwards. (Note: This is not mandatory but I found it helpful for the next step)
    STEP 11: ENSURE THAT THE IGNITION IS OFF AT THIS STAGE TO PREVENT POSSIBLE FAULT CODES FLAGGING UP!
    Remove the bumper from the car by gently wiggling and pulling on all sides, foglight hole, and from top and bottom. (Note: this is where step 10 proves useful). Make sure that protective matting is in place in front of the bumper in case the bumper is dropped etc. Be aware that the bumper will still be attached to the car at this stage, via wires.
    STEP 12: Once the bumper is free, the airtemp sensor will then need to be removed from the bumper by gently pulling it free.
    STEP 13:
    Unplug the foglights by using a screwdriver to unclip the socket.
    The bumper will now be fully free from the rest of the car at this stage.
    STEP 14: Place the bumper face down on the protective matting and locate the 12 bolts indicated below.
    Remove these bolts using a t26. The bottom bracket indicated below can be removed once the 6 bolts holding it in have been taken out. This bracket has to be added to the replacement grille.
    STEP 15: Unclip the 4 clips, 2 on either side of the top of the grille, using a screwdriver.
    STEP 16: Unclip the 4 clips, 2 on either side of the grille, using a screwdriver.
    CURRENT: 2009 Audi A4 2.0 TFSI S line, Misano Red, 19" Black Edition Rotors, RS4 Grille, Sat Nav, AMI, Bluetooth, Phone & Voice Prep, CD Changer, Gloss Pack, Heated Seats, Cruise Control, Electric Folding Mirrors, Rear Window Tints, S line Suspension, Dynamic Boot Spoiler, K&N Typhoon Induction Kit
  2. RS4 Grille Fitment/Removal Guide
    Oct 2012
    Moray, Scotland
    STEP 17: Locate the 5 clips, 4 of which are indicated below.
    Unclip these clips by gently pushing down with a small screw driver.
    The grille will now become free from the bumper.
    STEP 18: Turn the grille over and locate the 10 clips on the back of the Audi logo.
    Unclip these clips by pushing the black clips attached to the grille, away from the chrome part of the Audi logo, using a small screwdriver.
    Once these clips have been unclipped, the Audi logo will now be free from the grille. This can be easily attached to the emblem holder of the new grille.
    THE FINISHED PRODUCT
  3. Re: RS4 Grille Fitment/Removal Guide
    Sep 2013
    leatherhead, UK
    Well since no one else has thanked you for the comprehensive set of instruction yet - I will. Brilliant.
    Anyone answer the question about fitment to an SE that's been left hanging?
    Audi A4 Avant B8 3.0TDI (240)
    Caterham 7 K series 1.8 150 ps
  4. RS4 Grille Fitment/Removal Guide
    Oct 2012
    Moray, Scotland
    Thanks mate!
    I believe that non SE bumpers do not have the bracket in Step 14 (picture 2).
  5. Re: RS4 Grille Fitment/Removal Guide
    Mar 2014
    Shavington England
    New comer to the forum only recently become the owner of my b8 and looking forward to making some changes and your thread is going to make one of the things on my to do list a lot easier great thread thanks
  6. Re: RS4 Grille Fitment/Removal Guide
    Mar 2014
    Northumbeland
    Is the A5 sline similar. It looks like it as I've had the lights out before and you need to remove all the plastic inners for that.
    Good guide. Well done.
  7. Re: RS4 Grille Fitment/Removal Guide
    Oct 2012
    Moray, Scotland
    Quote Originally Posted by Rosie Quattro View Post
    I believe the A5 has 2 bolts in the wheel arch under the lining as opposed to the 1 in the A4.
  8. Re: RS4 Grille Fitment/Removal Guide
    Mar 2014
    Shavington England
    Well I have just finished fitting the grille plus new led fogs and replaced a damaged fog grille. Followed your thread brilliant although I did have a little panick attack when it came to actually getting the bumper and grille off the sides need bit of coaxing but great all done chilling now with a well earned cold one thanks
  1. RS4 Grille query
    By quattrodlo in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 03-09-2011, 10:10 AM
  2. rs4 replica fitment
    By maka10 in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-02-2010, 03:41 PM
  3. Question RS4 dead pedal fitment on Automatic
    By RAUDIE in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 17-11-2008, 07:01 PM
  4. Question Replacing an S-Line grille with an RS4 grille
    By toff in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-06-2008, 05:32 PM
  5. rs4 alloy fitment
    By t5psr in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 11-09-2007, 10:16 PM
