Thread: Dpf regen
Page 1 of 3 123 LastLast
Results 1 to 10 of 22
  1. Question Dpf regen
    Nov 2013
    Forres
    Hello. I'm needing to carry out a forced regen on the 2.0tdi BRD r4 engine. I've manually regenerated it to bring my soot levels down. Does anyone know the security access key/pin so I can use the forced regen function? Thanks I. Advance.
  2. Re: Dpf regen
    Southern County Softy
    20 Post(s)
    Check this is the right one for your engine.
    Diesel Particle Filter Emergency Regeneration - Ross-Tech Wiki
    Sent from my GT-I9505 using Tapatalk
    A4 2.5 tdi QS (mapped)
  3. Re: Dpf regen
    Nov 2013
    Forres
    I carried out the top procedure and drove for ages and manages to get the soot just under 40. It was up at 120ish. The glow plug light still flashing and dpf light still on. Can erase dtc but comes straight back on. All exhaust temps are showing good 800degrees before turbo and can see it going into normal regen but never completed. Figured a forced regen would sort it. Normally work with Nissan and forged regen cures it 98% of the time. Dtc is 008194 (particulate trap bank1) p2002 - 006 efficiency below threshold.
  4. Re: Dpf regen
    20 Post(s)
    Sensors are known to fail.
  5. Re: Dpf regen
    Nov 2013
    Forres
    Would it not show a dtc for the failed sensor though? It's a 2007 so not sure if it come under the top or other process on wiki. Top was working,just couldn't get lights off. So thought forced would reset system. So access code would be idea to try,failing that is there anything else I could try to figure the problem?
  6. Re: Dpf regen
    20 Post(s)
    Thats me out of ideas.
  7. Re: Dpf regen
    Nov 2013
    Forres
    Haha,not a problem bud. Cheers for your input. Hopefully someone else might have some view.
  8. Re: Dpf regen
    46 Post(s)
    And the fault code is ....
  9. Re: Dpf regen
    Nov 2013
    Forres
    It's inthe 3rd post at the end. I'm on mobile so wrote it down. Sorry
  10. Re: Dpf regen
    Nov 2013
    Forres
  1. DPF regen from a cold start?
    By fat controller in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-06-2014, 07:36 AM
  2. Question Gt170 DPF regen
    By mark wade in forum Golf MK5 - 2004 - 2009
    Last Post: 13-07-2013, 06:30 PM
  3. DPF Regen
    By Sportwag in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-01-2012, 06:42 PM
  4. Question 2.0 TDI DPF Regen Cycle
    By John140 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 16-06-2011, 01:26 PM
  5. DPF regen - hot turbo
    By patrickhorton in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 04-02-2011, 09:16 AM
