Thread: Active cruise alignment
Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
  1. Re: Active cruise alignment
    #11
    Jul 2013
    76 Post(s)
    I have found this,, i don't know if any good for you but you never know.
    "I have calibrated the ACC sensor today and figured out the coding for the ABS controller which is 0562321."
    Taken off this post
    http://audiforum.us/threads/adaptive-cruise-control-acc-retrofit-on-a6.8260/page-6
  2. Re: Active cruise alignment
    #12
    Nov 2009
    46 Post(s)
    Quote Originally Posted by dan2485 View Post
    Taken off this post
    Thats just the short coding for the abs module, don't think it would help with the alignment of the radar.
  3. Re: Active cruise alignment
    #13
    Jul 2013
    76 Post(s)
    Calibration can also be done with a laser pointer unit.
    Park the car on a flat parking with 30-50 metet free space in front of car.
    Line up 2 object 30-50 meter in front of car that are aligned to the outside of the tires, left and right side.
    Now place the laser pointer at the same height as the radar 30-50 meter in front of car, in the middle of the 2 objects.
    Point the laser to the small mirror on the radar unit. Go back to the car and adjust the radar head so the reflected laser beam hits the laser pointer unit.
    Do this in the evening so you see the laser beam.
    A DIY laser level should do the trick.
  4. Re: Active cruise alignment
    #14
    Apr 2009
    Now place the laser pointer at the same height as the radar 30-50 meter in freeont of car, in the middle of the 2 objects.
    I have this on my car and when using it I put A LOT of trust in the whole system working properly as can make my 25 mile journey to work effortless. I've seen me hit the motorway and set it at 70 and not have to touch a thing til my turnoff which is about a 20 mile stretch as the car brakes and accelerates on its own and keeps perfect distance from the car in front so bearing all that in mind if you can I'd be taking to Audi to get properly set up, may cost a bit but worth it for peace of mind and the resale value.
  5. Re: Active cruise alignment
    #15
    Feb 2010
    Wirral
    Sensor itself ok, bracket got bent and comes up with Active cruise not available, Spoiler and bumper sprung back and just scratched. Should be simple fix but apparently it damaged the heated cover and will not work without it so need this at £250 plus a re-alignment cost,
    1986 Coupe quattro, (looks standard but hides 420bhp 20Vt).
    2004 A4 2.5TDi (163bhp) Sport cabriolet. Economy remap to 180bhp.
    2011 A5 Sportback 3.0TDi S-Line manual.
  6. Re: Active cruise alignment
    #16
    Jul 2013
    76 Post(s)
    Buy the bracket and then I would at least try the above post first.
    If all else fails then take it to Audi.
    It is a simple thing to do all you need is a laser lever (£10 ish) and a tape measure to know what the height should be plus a block to set the laser level on.
    Dan
  1. Please Help VW Golf Immobilser active
    By bhp555 in forum Golf MK5 - 2004 - 2009
    Last Post: 06-10-2012, 10:24 PM
  2. Please Help Immobiliser Active!
    By johnnypbristol in forum Jetta MK3 - 2005 - 2013
    Last Post: 12-08-2010, 10:02 AM
  3. Automatic run active?
    By Pernicitus in forum VCDS - General Questions
    Last Post: 30-08-2009, 08:50 AM
  4. over active immobiliser
    By richard01276 in forum Audi A4 - Archive Topics
    Last Post: 11-01-2008, 08:38 PM
