Thread: Possible leak from panoramic sunroof.
  1. Possible leak from panoramic sunroof.
    Aug 2007
    North West UK
    After finding a substantial pool of water in the spare wheel well of our Golf estate, I have explored the possible causes and come to the conclusion that it could be coming from the panoramic sunroof.
    If anyone has any experience of this, or other thoughts on possible causes, I would be very grateful to hear them.
    Thanks,
    Russ
  2. Re: Possible leak from panoramic sunroof.
    46 Post(s)
    Check the sun roof drainage channels are clear from debris, also check your rear lights aren't letting in water either.
  3. Re: Possible leak from panoramic sunroof.
    Aug 2007
    North West UK
    Hi again Chris,
    I will check the drainage channels tomorrow. Its interesting you mentioned the rear lights, as the offside light is misting up a little, since the car was bumped on that corner during last summer. The seal seems ok, but is something I am keeping an eye on.
    I also had a DAB antenna fitted last October, and some of the trim around the tailgate looks a bit ill fitting, I will address this soon.
    Thanks,
    Russ
  4. Re: Possible leak from panoramic sunroof.
    Aug 2007
    North West UK
    Hi Chris, I have been trying to find the source of my leak and have concluded that the water is coming in from high up in the car. i.e. the sunroof or aerial. As the aerial is only a small area, I am more inclined to think it is the panoramic sunroof. The trouble I am having is locating the drain holes for this, I assume being a large area that it will have at least 4 drains. I can only locate the front 2. The rear glass section is fixed, so I don't know if there are any drain holes under this. I have trawled the interweb trying to find the location of these, but with no joy. Do you have any idea how I can find out where these drains are? Thanks, Russ
  1. Just ordered a BiTdi - should I add a panoramic sunroof?
    By nuty_bloke in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 01-04-2014, 02:56 PM
  2. Anyone got a Panoramic Sunroof?... Worthwhile?
    By thehorse in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 11-06-2012, 10:32 PM
  3. Panoramic sunroof owners
    By SunnyBard in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-06-2011, 05:51 PM
  4. Panoramic Sunroof - feedback please?
    By Drifty in forum Passat CC
    Last Post: 25-10-2010, 07:10 PM
  5. Question Panoramic Sunroof seals perished within a week
    By wrightee in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 03-10-2008, 07:16 PM
