Thread: A3 wing mirror help
  1. A3 wing mirror help
    Mar 2014
    Lockerbie, Scotland
    Hi everyone,
    I've just bought a A3 1.9tdi sport hatchback 2005. Everything works apart from the exterior mirrors. They won't adjust or heat.
    I have tried to locate a fuse but unless I'm blind I can't see where it's located.
    Please can can anyone offer some advice as to what might be wrong with them?
    thanks in advance
    steve
  2. Re: A3 wing mirror help
    46 Post(s)
    Check the fusebox on the end of the dashboard behind the pop off panel on the driver side.
    There will be a diagram on the back of that, is be getting a scan done also.
    Oh and check the wiring going from the car into the door for cracks or splits.
  3. Re: A3 wing mirror help
    Mar 2014
    Lockerbie, Scotland
    Cheers Chris, I looked in the fuse box but it doesn't say anything for wingmirrors, I've also looked in the fuses under the bonnet. Wires are all intact, it's a strange one because all the things that I've read about suggests that when the mirrors stop working so do the electric windows.
    Could it be the control switch?
  4. Re: A3 wing mirror help
    46 Post(s)
    Switch could be an issue but a scan will show what's up.
  5. Re: A3 wing mirror help
    Mar 2014
    Lockerbie, Scotland
    No worries I shall get it checked. Thanks
  6. Re: A3 wing mirror help
    Jan 2012
    Coding Something
    Use vcds with measuring blocks to check the switch positions are being seen, power is supplied via the door module.
  1. New wing mirror?
    By poosnip in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 13-12-2013, 01:37 PM
  2. How do I take apart my wing mirror?
    By sportbackbkd in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 22-08-2010, 12:00 PM
  3. Wing mirror
    By p1lts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 20-08-2010, 11:44 AM
  4. Wing mirror
    By stilltickdogg in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 08-01-2010, 08:40 PM
  5. Question Wing mirror
    By cdti in forum Golf MK5 - 2004 - 2009
    Last Post: 08-12-2009, 05:05 PM
