hi there, wondering if anyone can help. golf 1.9tdi 57plate.
both these warning lamps displayed at same time. (wet weather)engine management system fault lamp flashing /esp fault warning lamp solid. the car was at vw dealers last week for same problem. "gff fault listed for speed sensor" wiring repaired as had started to "buff " notes on bill for work completed says if fault reoccurs speed sensor requires replacement.
would i be correct in saying they are talking about speed sensor for one of the 4 wheels. Have been out in the car since first repaired (dry road) and no problems. just today it was raining and warning lamps came on within ten minutes of driving.
anyone any ideas if anything else might be causing the problem.......apart from the wet road/puddles!!!!!!
thanks in advance
