Thread: dump valve
Page 3 of 4 FirstFirst 1234 LastLast
Results 21 to 30 of 32
  1. Re: dump valve
    #21
    May 2007
    how do you know if your dv is broke
  2. Re: dump valve
    #22
    As far as I know if they are broken its because the diaphragm ruptures, in which case it would either not hold the full pressure in, or would just constantly vent the pressure and you would subsequently loose some of/all of the effect of the turbo.
    I don’t believe it could actually stick closed, in which case your turbo would shatter because as soon as you eased off the throttle and the turbine had stopped spinning (lets say clockwise) the pressure not vented would immediately start it spinning the other way (anti-clockwise).
  3. Re: dump valve
    #23
    May 2007
    think mine is broke as it keeps going woosh every time i come off the throttle
  4. Re: dump valve
    #24
    Ah, doesn’t sound like yours may actually be broke, sounds like you’ve got a chavy ‘Atmospheric’ DV rather than the standard fit and preferable ‘Recirculating’ DV.
    Speak to Forge and tell them what engine you’ve got, what power its pumping out (or is likely too for the foreseeable future) and ask for a decent Recirculating DV.
  5. Re: dump valve
    #25
    May 2007
    Thats just it the dv has never been replaced and is a standard unit
  6. Re: dump valve
    #26
    In which case replace with either a new OEM, or an upgraded one from say Forge.
  7. Re: dump valve
    #27
    Sep 2007
    What is an OEM ? does have a dump valve increase BHP?
    i might get one fitted if it increases the BHP?
  8. Re: dump valve
    #28
    A, A
    Quote Originally Posted by 1staudiA3 View Post
    Original Equiptmant Manufacturer, Standard one in other words.
    DV's do not increase BHP.
    Just another B7 Estate
  9. Re: dump valve
    #29
    Sep 2007
    i wanna increase BHP got any tips apart from Remapping ?
  10. Re: dump valve
    #30
    Feb 2007
    kent
    Quote Originally Posted by ashleytinman View Post
    You might be able to help me then i've got an Bmc air filter its the carbon one and looked today thinking of fitting it and realised there is a other set of wires coming out of the air box are there to an other air mass meter or what???? how can i fit my induction kit with out the wires in the air box and what would it do if i did??? Did you notice any difference when you fitted a panel filter and did it make any difference in sound.
    I found this on mine, so i ordered a induction kit from jabba, the wires you are on about go to a temp sensor( i think )so it has to be mounted by the filter mine goes on the metal panel which stops the heat getting in the filter. I aint had any probs yet, and i'm sure the BMC set up should work well with the sensor fitted close by.
    I had the same problem, no one wanted to tell me what it was for thats why i went to jabba sport. But knowing what i know now i would have gone for the BCM. Good luck.
    Nick
  1. 1.8T dump valve
    By whelme in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 13-03-2008, 04:54 PM
  2. Dump Valve?
    By Turkster in forum Passat - B5 Forum - 1997 -2005
    Last Post: 18-06-2007, 11:59 PM
  3. 1.8t Dump valve
    By Nav_1.8t in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 13-06-2007, 02:15 PM
  4. Dump Valve A4 1.8T
    By waynerooks t4 in forum Archive posts
    Last Post: 05-06-2007, 10:41 PM
  5. replacing atmospheric dump valve with re-circ dump valve
    By vwgolfturbo in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 04-02-2007, 10:27 PM
