Thread: HELP MK3 golf speedo not working.
  1. HELP MK3 golf speedo not working.
    Hi all l wonder if anyone can help the speedo on my mk3 golf has died and despite tinkering l am at a loss. I have tried an alternative console to no effect, changed the sender unit on the gearbox and still l am doing 0mph wherever l go. l believe this may be a common fault thus should have a common fix but l am at a loss and running the SP30 risk on a daily basis (when l get to the motorway its HGV plus 400 revs and l think l am about right!!) So any help would be greatly appreciated.
    Mark
  2. Re: HELP MK3 golf speedo not working.
    Jul 2008
    hi,
    had the same problem with my mk3 golf speedo
    I also changed the gearbox sender unit, still zero mph
    When I removed the speedo cluster to have a look, I found that the
    solder joints at the multi connector to the circuit board had dry joints.
    A quick re-solder of these pins and speedo now working
    saved sending it away to cluster repairs . com
    kerso
  1. mk3 golf speedo sensor?
    By BugsyMalone666 in forum Golf MK3 - 1993 - 1999
    Last Post: 27-06-2009, 11:09 PM
  2. Mk4 Golf - speedo and fuel gauges playing up
    By aBoijj in forum Golf MK4 - 1999 - 2004
    Last Post: 28-08-2007, 12:38 PM
  3. Golf Speedo dropping off
    By mattsgolf in forum Golf MK4 - 1999 - 2004
    Last Post: 07-03-2007, 03:27 PM
  4. electronic speedo is not working
    By Dataman in forum Golf - Jetta - Vento - Bora - Archive Topics
    Last Post: 12-02-2007, 08:21 PM
  5. Golf mk4 Speedo completely wrong???
    By liamcartwright in forum Golf MK4 - 1999 - 2004
    Last Post: 29-08-2006, 04:24 PM
