Thread: Revs Not Dropping
Results 1 to 8 of 8
  1. Revs Not Dropping
    Jan 2014
    Surrey
    I've noticed something on my A4 but I'm unsure if it's normal for the car.
    It's a 2008 2.0t and I'm finding that when I dip the clutch to change up a gear the revs still stay pretty high, usually not dropping much below 2k RPM.
    Is this normal for the 2.0t petrol models?
    I've had the car scanned on VCDS and it came up with a stored fault on the stop light switch and one for the clutch switch. Other than that there was nothing.
  2. Re: Revs Not Dropping
    46 Post(s)
    You listed the faults, brake and clutch switch. Replace those and problem solved
  3. Re: Revs Not Dropping
    Jan 2014
    Surrey
    Thanks for that!
    That should be a pretty straightforward fix then
  4. Re: Revs Not Dropping
    46 Post(s)
    Yep should be, get genuine parts from Audi
    And welcome.
  5. Re: Revs Not Dropping
    Jan 2014
    Surrey
    And welcome.
    I will do, I'll get on to them tomorrow and see if they've got any in stock.
    If they're anything like Mercedes, they'll have any amount of stop light switches available as they seem to break so often!
  6. Re: Revs Not Dropping
    Jan 2014
    Surrey
    I managed to get a chance to sort this eventually!
    I replaced the stop light and clutch switches, a total of £29 and about 15 minutes work. The car drives so much better now for it, thanks for the advice!
  7. Re: Revs Not Dropping
    46 Post(s)
    Quote Originally Posted by graemetee View Post
    Congrats on the easy fix!
  8. Re: Revs Not Dropping
    Jan 2014
    Surrey
    I just hope that any other fixes it needs are as easy!
    Next thing to look at is the climate control that seems to have a mind of it's own
  1. Question Revs dropping slowly
    By Doctle Odd in forum Chat - Completely Off Topic
    Last Post: 29-03-2013, 06:54 PM
  2. Question Revs not dropping as they should
    By lukieno1 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 05-03-2013, 01:37 PM
  3. Revs dropping
    By Mathematics in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 20-02-2013, 11:39 AM
  4. revs dropping
    By mbjoyce in forum Passat - B5 Forum - 1997 -2005
    Last Post: 14-03-2009, 08:11 PM
  5. mk3 dropping in revs
    By aharrod in forum Golf MK3 - 1993 - 1999
    Last Post: 09-11-2007, 12:07 PM
