Thread: 1.9 TDi big oil leak from EGR vent holes
Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
  1. Re: 1.9 TDi big oil leak from EGR vent holes
    #21
    1834 Post(s)
    Scoup, stab, scrub and leave overnight in TFR, fit a new EGR and V157.
  2. Re: 1.9 TDi big oil leak from EGR vent holes
    #22
    I owned 2 PD Passats, I did 200K in them, I had to clean the inlet manifold and replace the EGR on one, I also had to drain 1lt of oil out of the intercooler (I drilled a hole and tapped it to do this on services) from the same car. I never got more than a thimble full of oil out of the drain hole after that and the other passat never suffered from the same. I think its is either down to a very heavy boot or using the wrong oil. I agree re the mess it makes when you clean one, carbon and oil is a very penetrative mix, plays havoc with the manicure.
  3. Re: 1.9 TDi big oil leak from EGR vent holes
    #23
    Feb 2012
    UK/Staffordshire
    The biggest problem with this build up is your driving style! I had mine out once and had nothing to clean light thin layer of oil ...
  4. Re: 1.9 TDi big oil leak from EGR vent holes
    #24
    Was that an echo?
  5. Re: 1.9 TDi big oil leak from EGR vent holes
    #25
    Feb 2012
    UK/Staffordshire
    Quote Originally Posted by caldirun View Post
    Was that an echo?
    Standart a4 b6 1.9tdi avb, 256 000miles most mine, own it for nearly 10 years .. never been in service except for tires i dont trust them.. Not sure what you mean with echo..
  6. Re: 1.9 TDi big oil leak from EGR vent holes
    #26
    My post "I think its is either down to a very heavy boot or using the wrong oil"
    Your post "The biggest problem with this build up is your driving style"
    An echo!
  7. Re: 1.9 TDi big oil leak from EGR vent holes
    #27
    Feb 2012
    UK/Staffordshire
    An echo!
    Ahh sorry, English is my third language..
    I can confirm heavy leg has nothing to do with this.. All i have done is spirited driving.. Might be oil choice.. Cant believe Audi thinks this is normal..
  8. Re: 1.9 TDi big oil leak from EGR vent holes
    #28
    1834 Post(s)
    Ohh, may favourite job.....
  1. What are these vent like holes in the courtesy light console?
    By kerbdog in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-06-2011, 03:08 PM
  2. 130 TDI Oil leak from EGR area and heavy breathing
    By speed12 in forum Bora - 1998 - 2005
    Last Post: 05-06-2011, 05:05 PM
  3. Please Help big oil leak
    By ianbts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-07-2010, 06:54 PM
  4. Oil Leak from EGR
    By blackps in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2008, 07:05 PM
  5. Oil leak from the EGR
    By wilharper2000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-04-2007, 11:45 AM
