Thread: 1.9 TDi big oil leak from EGR vent holes
Results 11 to 20 of 28
  1. Re: 1.9 TDi big oil leak from EGR vent holes
    May 2007
    knee deep in clunge
    14 Post(s)
    may be of help
    Secondary oil separator
    Secondary oil separation is provided by a cyclone
    oil separator with a pressure regulating valve.
    Cyclone oil separators are also known as centrifugal
    oil separators. Their functional principle is based on
    the induction of rotational movement in an oil-gas
    mixture by channelling the flow.
    The centrifugal force accelerates outwards the oil
    droplets, which are heavier than the gas. The oil
    droplets deposit on the wall of the cyclone oil
    separator and drip through a drain hole into the
    cylinder head. The cyclone oil separator has the
    capability to separate very fine oil droplets.
    A damping chamber adjoining the cyclone oil
    separator prevents unwanted turbulence when the
    gas flows into the intake manifold. The damping
    chamber reduces the kinetic energy of the gas.
    A residual amount of oil also precipitates out inside
    the damping chamber.
    So oil consumption requires checking to see if excessive so as to rule out consumption or to prove it, having mentioned the blow pass builds up so if the engine breathers are in order and the turbo is not allowing oil to pass then the build up from the breather allowing oil into the inlet combined with turbo pressure means oil is circulating and leaking from the weakest points
  2. Re: 1.9 TDi big oil leak from EGR vent holes
    1836 Post(s)
    New EGR valves don't leak oil, in fact I would say most don't. We always note it down on the service inspection sheet and of the twelve TDI's we serviced last week, not one had this noted down by the mechanic. If they look this this then we do suggest replacement.
    Some cars I get come in with tiny holes drilled in the lowest point of the intercooler, one I saw recently had a tiny metal pipe glued to the surrounding area to bleed off the oil. I wonder how much boost that would loose? Probably not very much.
    Anyway, its no big deal.
  3. Re: 1.9 TDi big oil leak from EGR vent holes
    Feb 2012
    UK/Staffordshire
    Sorry to bring up an old tread but,How is egr related to the actual problem OIL LEAK why bother with egr if it has no idea where the oil came from and decides to spit it out and is actually a good thing because it doesn't end up on inlet valves and cake the whole thing even quicker.. try to clean them off hah people use valve cleaning miracle in random bottles and brands but actually there is no way it can get on top of the valves lol. Oil is coming from crankcase breather hose as natural process in time it can get a bit worse. It can be confusing and seem like the oil is coming from the turbo itself but that is not necessary the case. What upsets me is that the egr is not effective and could have small tubes coming down and end up in a small like collector pot so we can just pour out the oil like a maintenance thing. Take a pipe of the crankcase breather and try to block it with your finger after few seconds let it go and you will notice it has build quite a pressure and is eager to escape if this is not the case then it might be blocked maybe because of very rare oil changes and it just blocks the pipe with jelly oil.. But i can't see this happening this would be an extreme case.. I hope the web search finds this useful one day.
  4. Re: 1.9 TDi big oil leak from EGR vent holes
    1836 Post(s)
    Because some people don't like oil leaks.
  5. Re: 1.9 TDi big oil leak from EGR vent holes
    May 2012
    Everywhere
    308 Post(s)
    On a pre 2003 just pull the egr vac line and plug the atmospheric holes .
  6. Re: 1.9 TDi big oil leak from EGR vent holes
    1836 Post(s)
    Tut tut, and you wonder why diesel is being demonised!
  7. Re: 1.9 TDi big oil leak from EGR vent holes
    #17
    May 2012
    Everywhere
    308 Post(s)
    There's the egr demon .
  8. Re: 1.9 TDi big oil leak from EGR vent holes
    #18
    I had the same problem, take the inlet manifold off and clean, replace the EGR valve, easy peasy
  9. Re: 1.9 TDi big oil leak from EGR vent holes
    #19
    1836 Post(s)
    Easy but when you have to do one a week it gets depressing...... and ditched, you should see the colour of the water when you take a shower......
  10. Re: 1.9 TDi big oil leak from EGR vent holes
    #20
    May 2012
    Everywhere
    308 Post(s)
    What's your method of cleaning 'em Stevie?
  1. What are these vent like holes in the courtesy light console?
    By kerbdog in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 28-06-2011, 03:08 PM
  2. 130 TDI Oil leak from EGR area and heavy breathing
    By speed12 in forum Bora - 1998 - 2005
    Last Post: 05-06-2011, 05:05 PM
  3. Please Help big oil leak
    By ianbts in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 10-07-2010, 06:54 PM
  4. Oil Leak from EGR
    By blackps in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 21-12-2008, 07:05 PM
  5. Oil leak from the EGR
    By wilharper2000 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-04-2007, 11:45 AM
