Thread: 2009 A6 MMI - Bluetooth & Sat issues
Page 2 of 5 FirstFirst 1234 ... LastLast
Results 11 to 20 of 43
  1. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    Correct, the side of the module is only the rest of the glovebox, which is fully intact.
  2. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    The side is set out as per a normal glove box, no alterations visible.
  3. Re: 2009 A6 MMI - Bluetooth & Sat issues
    43 Post(s)
    Then you're not missing anything, there was an optional cd changer for 3G which would be in that other slot so nothing's missing.
    I suggest getting the firmware update done by Audi and go from there. If you press TEL the SETUP can you search for your phone then?
  4. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    When pressing the TEL function the screen gives you the option to search for a bluetooth handset. When the search button is pressed the screen shows a searching symbol for around 4-6 seconds then it ceases and states that 'mobile device not found'.
  5. Re: 2009 A6 MMI - Bluetooth & Sat issues
    43 Post(s)
    Which phone are you using? Are there any metal contacts in the armrest?
  6. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    I have tried both iphone 4s, 5s and blackberry. In the centre armrest their is a section with brass contacts which AUDI have confirmed that is the 'docking station' for the Audi phone cradle.
  7. Re: 2009 A6 MMI - Bluetooth & Sat issues
    #17
    43 Post(s)
    Well for the iphone it's only used for charging. I'd be getting the firmware update and see what that brings considering you have a software related fault code aswell.
  8. Re: 2009 A6 MMI - Bluetooth & Sat issues
    #18
    Apr 2007
    OK so its a trip to the main dealer then!
  9. Re: 2009 A6 MMI - Bluetooth & Sat issues
    #19
    Nov 2014
    Carlisle, Cumbria, United Kingdom
    Yogi - Did you ever resolve your problem? I have the exact same set-up as you with the exact same problem.
  10. Re: 2009 A6 MMI - Bluetooth & Sat issues
    #20
    Jan 2015
    SK
    Quote Originally Posted by Yogi View Post
    Hello,
    Not sure if this has been answered elsewhere but i am having problems finding an result.
    I have recently purchased a 2009 A6 LeMans edition and my MMI unit has as follows:
    All control buttons around the MMI Wheel (No joystick), colour screen and a module unit in the glove box with 'multimedia' branded on the unit with 2 x SD cards.
    I think the unit is a 3G model, but need some advice from experts on the forum.
    AND
    When activating the bluetooth it attempts to search for approximately 4-6 seconds and then reads that no devices found, Mobile phones also cannot find the Audi bluetooth signal.
    And
    When i press the Nav button it reads 'Navigation not available at the time', so not sure how this can be rectified.
    I have been on the menu option and cannot find the SW codes but i have found under the engineering menu, current train version : P0020_ADJBK_FIX
    MU Software: 0040
    Audi have quoted me 105 for a software update but also stated that this may not clear the issue
    Has anyone come across this issue before and know of any way to resolve bluetooth and SAT problems??
    Any help would be greatly appreciated!!
    regards
    Kevin
    Dear Yogi,
    I give you some update, because I just had car with same problem. First, "Navigation not available at the time" means you do not have navigation. They do not make extra buttons board without Navi button, so button is there, but it will show you that message.
    MMI 3G early version (I'm not sure if only P0020 or also another) have sw bug which destroy bluetooth after some time. To confirm this, turn off completely MMI by pressing volume button for 5 seconds (or perform 3 key combination for reset) and check if you see during booting "Audi Multi Media Interface" boot screen, if you see only black screen it is the BT problem.
    If BT is damaged, you must first use the Audi BT fix CD (the firmware P0020_ADJBK_FIX) and ONLY AFTER you can upgrade firmware to higher version. If you just upgrade to higher FW version, you will destrou BT permanently.
    I can guess in your case, somebody upgraded firmware, and then use the BT fix CD. I'm not sure if MMI will accepted downgrading to lower firmware or not, if not you can still override this somehow, so my theory should be correct. And should be reason why you have firmware P0020_ADJBK_FIX but BT is not working.
    That means you need buy used MMI main unit for about 400 EUR on ebay, replace it and then go to Audi to allow it via car diagnostic.
    Good luck.
  1. MMI DVD Sat Nav in 2009 SE
    By boronet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2013, 11:09 AM
  2. Replies: 13
    Last Post: 21-11-2013, 12:17 PM
  3. Dension Gateway 500S for an Audi A6 MMI 2g - Bluetooth issues
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-09-2013, 11:48 AM
  4. Audi MMI 3G Low Samsung Galaxy S3 Bluetooth Issues
    By JKA4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-09-2013, 08:44 AM
  5. Install MMI sat Nav & Bluetooth
    By Kennylen in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-04-2011, 11:20 AM
