Thread: 2009 A6 MMI - Bluetooth & Sat issues
Page 1 of 5 123 ... LastLast
Results 1 to 10 of 43
  1. 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    Hello,
    Not sure if this has been answered elsewhere but i am having problems finding an result.
    I have recently purchased a 2009 A6 LeMans edition and my MMI unit has as follows:
    All control buttons around the MMI Wheel (No joystick), colour screen and a module unit in the glove box with 'multimedia' branded on the unit with 2 x SD cards.
    I think the unit is a 3G model, but need some advice from experts on the forum.
    AND
    When activating the bluetooth it attempts to search for approximately 4-6 seconds and then reads that no devices found, Mobile phones also cannot find the Audi bluetooth signal.
    And
    When i press the Nav button it reads 'Navigation not available at the time', so not sure how this can be rectified.
    I have been on the menu option and cannot find the SW codes but i have found under the engineering menu, current train version : P0020_ADJBK_FIX
    MU Software: 0040
    Audi have quoted me 105 for a software update but also stated that this may not clear the issue
    Has anyone come across this issue before and know of any way to resolve bluetooth and SAT problems??
    Any help would be greatly appreciated!!
    regards
    Kevin
  2. Re: 2009 A6 MMI - Bluetooth & Sat issues
    42 Post(s)
    You have 3G Low.
    I suggest getting a fault code scan as these are complicated systems, I also suggest getting the update done also.
  3. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    Thanks Chris, Fault code scan reads:
    Address 5F: Information Electr. (J794) Labels: 4E0-035-6xx-5F.clb
    Part No SW: 4E0 035 646 B HW: 4E0 035 646
    Component: B-B-ER H51 0040
    Revision: -------- Serial number: 348D$097523469
    Coding: 010001000102C3ED01000305EF6300030201
    Shop #: WSC 00134 210 91052
    VCID: 234F8479223055001CE
    Subsystem 1 - Part No SW: 4L0 919 604 HW: 4L0 919 604
    Component: DU6 Basic H43 0306
    Subsystem 2 - Part No SW: 4F0 910 609 E HW: 4F2 919 611 H
    Component: Bedienteil MM H01 0060
    1 Fault Found:
    03276 - Please Check Software Version Management
    000 - -
    Freeze Frame:
    Fault Status: 01100000
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 23
    Mileage: 74249 km
    Time Indication: 0
    Date: 2013.04.23
    Time: 12:45:22
    Freeze Frame:
    Voltage: 12.20 V
    Not sure if you can understand the specific codes. How do I go about getting an update carried out? Is anything available to download?
    regards
    Kevin
  4. Re: 2009 A6 MMI - Bluetooth & Sat issues
    42 Post(s)
    Let Audi do their update as it all has to be activated/approved online with Germany.
    Has this been playing up for a while?
  5. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    I bought the car private 6 weeks ago and it has been an issue since i picked it up.
  6. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Jul 2011
    Near Uxbridge
    Maybe a daft question....in the glovebox is there both a CD player and a DVD player....have seen some where previous owner has removed the DVD player...which is the Sat nav media!
    Sent from my HTC One using Xparent Red Tapatalk 2
    2009 Audi A6 Avant 2.0 S-Line TDIe Phantom Black
    2009 Audi A3 Sportback 1.9 TDIe Sport Brilliant Red
  7. Re: 2009 A6 MMI - Bluetooth & Sat issues
    42 Post(s)
    If there was a device removed from the optical loop the system wouldn't function
  8. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    I only have 1 module in the glove box and it looks exactly like the attached pic
  9. Re: 2009 A6 MMI - Bluetooth & Sat issues
    Apr 2007
    Chris,
    Is there any way of establishing if something has been removed?
  10. Re: 2009 A6 MMI - Bluetooth & Sat issues
    42 Post(s)
    Nothing would work, you'd get as far as the MMI splash screen and no further. I assume the gap beside your sd card thing has a back on it and doesn't disappear into nowhere?
  1. MMI DVD Sat Nav in 2009 SE
    By boronet in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 17-12-2013, 11:09 AM
  2. Replies: 13
    Last Post: 21-11-2013, 12:17 PM
  3. Dension Gateway 500S for an Audi A6 MMI 2g - Bluetooth issues
    By sapstar in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 20-09-2013, 11:48 AM
  4. Audi MMI 3G Low Samsung Galaxy S3 Bluetooth Issues
    By JKA4 in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 12-09-2013, 08:44 AM
  5. Install MMI sat Nav & Bluetooth
    By Kennylen in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 21-04-2011, 11:20 AM
