Thread: EPB Module Failure, which part suffix/revision?
Page 2 of 2 FirstFirst 12
Results 11 to 14 of 14
  1. Re: EPB Module Failure, which part suffix/revision?
    #11
    Mar 2012
    Turkey
    Ebp button works fine. Ebp motors are working. If the boards were damaged it would not worked i think so
    SM-N910C cihazımdan Tapatalk kullanılarak gönderildi
  2. Re: EPB Module Failure, which part suffix/revision?
    #12
    Jan 2012
    Rustington, West Sussex UK
    10 Post(s)
    87 Post(s)
    Quote Originally Posted by drozia View Post
    So should i replace with b,e or g suffix? And i confused that as you stated if the damaged boards inside of module occur then any fault must be seen on vcds?
    VCDS can only interpret faults based on voltages and other electrical inputs. If a module is damaged by excess voltage VCDS will register what it thinks the problem is. It is not A.I. so not clever enough to actually tell you what is EXACTLY wrong, you have to do some detection work to narrow down the possibilities until you are certain you KNOW what is wrong. This may involve electrical diagrams, visual inspections, testing of associated parts and so forth. Some fault codes are extremely specific to certain conditions, others a little more vague. The dealer however renews parts at the customer's expense until the fault clears and does not come back - this can get very expensive as most know and does not always eliminate the cause.
    Mad Mitch
  3. Re: EPB Module Failure, which part suffix/revision?
    #13
    Mar 2012
    Turkey
    I will upgrade module to h suffix. This might be the best solution because older versions are being effected from low voltages and getting damaged. I replaced c series button but nothing has changed. So this is not a button fault issue. Thanks.
  4. Re: EPB Module Failure, which part suffix/revision?
    #14
    Jan 2012
    10 Post(s)
    87 Post(s)
    From memory I believe H modules should be ok and are not too new for the car as they will still be before the change to 30 byte, from 23 which start with the J revision. Older cars will not communicate with the newer 30 byte modules.
    Mad Mitch
  1. Bluetooth Module Failure
    By rictic68 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 11-08-2013, 09:23 PM
  2. Replies: 2
    Last Post: 17-08-2012, 08:00 PM
  3. Bosch 5.3 ABS Module failure or is it?
    By AudiGaGa in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 22-01-2011, 03:10 PM
  4. ABS pump/module part numbers
    By Bobby101 in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 09-11-2010, 07:57 PM
  5. Question Parking control module part no.s
    By Adman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 31-01-2010, 09:57 PM
