Thread: 17" b8 alloy wheels
Results 1 to 10 of 11
  1. 17" b8 alloy wheels
    Sep 2008
    Hi folks
    Does anyone know how wide this wheels are? I'm due tyres and was thinking of replacing with the 225/50 tyres with 235/40, but think that those wheels would need to be at least 7.5 wide?
    Thoughts?
    Sent from my GT-I9300 using Tapatalk
  2. Re: "17 b8 alloy wheels
    Southern County Softy
    20 Post(s)
    Is the wheel size not on the tyre pressure sticker inside of the drivers door.
    bloody smart phones....
    A4 2.5 tdi QS (mapped)
  3. Re: "17 b8 alloy wheels
    Sep 2008
    Good thinking batman! Will check when I'm back home, if they are 7.5 you think they are wide enough for 235's? I know the monte carlo alloys on the b6 sport passat have 235's not sure how wide those wheels are though
  4. Re: "17 b8 alloy wheels
    20 Post(s)
    No Idea sorry.
  5. Re: "17 b8 alloy wheels
    Sep 2008
    Checked the sticker on the door as suggested but it doesn't spec how wide the wheels are just gives different tyres/wheel combinations and their respective pressures, does anyone know the official name of that wheel? Might see if dealer can tell me, interestingly I decoded the sticker in the boot and seen that my car actually came with "18 alloys 235/40, so previous owner swapped them out
  6. Re: "17 b8 alloy wheels
    Oct 2005
    Do you have the part number?
  7. Re: "17 b8 alloy wheels
    Apr 2007
    Surrey
    I expect your local tyre fitter will know what's best for your size wheel...
    You're only adding 10mm to the tyre width (5mm each side obviously) so I don't think it will cause a problem. The side wall will also increase slightly but only by a small amount and I doubt it would be enough to throw the speedo out.
    2009 A4 2.0 TDI (170) Avant S Line Exec. ​Quartz Grey, S Line suspension (Optional), Bluetooth phone prep low, AMI, DAB, Symphony III, Leather/Alcantara, rear sun blinds, heated/dimming/folding mirrors and cruise control. Mods so far: BBS LM (reps), spacers (10mm f, 15mm r), needle sweep, dipping mirror on reverse and badge delete. To come: LED rear lights, lows and rear window tint.
  8. Re: "17 b8 alloy wheels
    Aug 2006
    By dropping to a 40 section tyre the overall diameter of the wheel/tyre combination will reduce, this will have an adverse effect on your speedo reading. Use the link to see the difference.
    Tire Size Calculator - Compare Two Sizes
  9. Re: "17 b8 alloy wheels
    Apr 2007
    Surrey
    Oops I missed that you were planning to reduce the profile - Soot1e is absolutely right, you need to keep the same rolling radius!
  10. Re: 17" b8 alloy wheels
    Sep 2008
    Thanks for the info guys, that's a handy site, and suggests that if my car came with 235/40/18 alloys originally according to its options sticker, then on its current wheels 225/50/17 the speedo is actually reading 2% faster as it is! Convincing enough argument for a set of new wheels!
  1. help with alloy wheels
    By cip82 in forum Chat - Anything with wheels
    Last Post: 27-10-2012, 02:33 PM
  2. alloy Wheels
    By shropslad in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 02-11-2009, 08:44 PM
  3. Alloy Wheels ?
    By calcoom in forum New Member Introductions
    Last Post: 28-10-2009, 07:53 PM
  4. alloy wheels
    By eddie v twin in forum Touran - Sharan - Caravelle
    Last Post: 08-12-2008, 05:42 PM
