Thread: Q7 Bluetooth a2dp ?
  1. Q7 Bluetooth a2dp ?
    Feb 2013
    Uk
    21 Post(s)
    I know bluetooth on my q7 doesn't support a2dp
    , is it possible to swap the blue tooth module with a later version of the audi Bluetooth module that does support a2dp
    qnd therefore stream music over BT
    ( I'm guessing it won't be as simple as just swapping modules!)
  2. Re: Q7 Bluetooth a2dp ?
    39 Post(s)
    Like I mentioned to you in PM, 2G will never support A2DP over factory bluetooth.
    You need AMI and the Tune2Air adapter.
  3. Q7 Bluetooth a2dp ?
    Buckinghamshire
    Or 3G + but either way it involves coin and faff
  4. Re: Q7 Bluetooth a2dp ?
    Feb 2013
    Uk
    21 Post(s)
    Ok cheers.
  5. Re: Q7 Bluetooth a2dp ?
    Feb 2014
    Cork, Ireland
    It can be done by changing the Bluetooth module to an aftermarket made by Kufatec. I have one in a D3 A8 with 2G MMI. MMI needs a software update to 5570 or newer. a2dp works perfectly with my iPhone but the mmi controls are via the CD function. You basically select the CD changer and select CD12. a2dp then starts up with a basic menu on the mmi screen which will start,stop,skip,fed etc but doesn't show track names, albums etc on the screen. Cost was £250 approx from memory.
  6. Re: Q7 Bluetooth a2dp ?
    39 Post(s)
    Fiscon
    Audi A6 FISCON MMI 2G BLUETOOTH KIT plug and play easy install | eBay
    Means changing a perfectly good bluetooth module for something which is aftermarket whereas OP could get AMI and have iPod/USB etc functionality with the addition of A2DP if he wants.
    My own opinion but may aswell do it right
  7. Re: Q7 Bluetooth a2dp ?
    Jul 2017
    Philippines
    Try viseeo tune2air from viseeousa.com. You can get the WMA3000A, plugs to AMI port. A simple device that can stream music, switch calls, control music with steering wheel controls. I have mine working smoothly in my car.
  1. A2DP Bluetooth Audio 3G MMI
    By superspurs in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-08-2017, 06:10 AM
  2. Question 2010 A4 with Audi Music interface - A2DP music Bluetooth dongle
    By Pbro in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 01-03-2013, 10:10 PM
  3. Replies: 1
    Last Post: 28-01-2013, 01:57 PM
  4. Question Bluetooth Ringtone, MMI 3G, Blackberry 8310, A2DP
    By Hippogriff in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 10-02-2010, 04:34 PM
  5. Question Will TomTom 540 bluetooth sync with A4 bluetooth phone prep 2nd Gen
    By foxyrider in forum In Car Entertainment
    Last Post: 14-01-2009, 11:39 AM
