Thread: A3 G85 implausible 00778 steering angle sensor
  1. A3 G85 implausible 00778 steering angle sensor
    Jan 2014
    Above error code has no basic setting has come up tried the usual fully left hold for 5 fully right hold for 5 then centre and drive. Cleared codes but lights and code still appear. Checked sensor and connection made sure it had equal turn each way so it's centre before putting it back in (is there a centre position on these?) reset and retested still the same. Replaced G85 sensor cost me a £100! Installed it did the same steering procedure I and cleared codes still getting the same messages, in vcds I'm getting 0 on angle also. Any ideas?
  2. Re: A3 G85 implausible 00778 steering angle sensor
    Oct 2005
    Welcome to VWAF
    Quote Originally Posted by Demo8Dan View Post
    The 'usual' is to follow the procedures listed on the Ross Tech wiki - see here for Conti/Teves MK70 ABS/ASR or here for Conti/Teves MK60 ABS/ASR/ESP where there is no mention of 5 or holding anything.
  3. Re: A3 G85 implausible 00778 steering angle sensor
    Jan 2014
    Thanks bud I will give it a go and follow procedures and report back 👍
  4. Re: A3 G85 implausible 00778 steering angle sensor
    Jan 2014
    Just to update this, I had to reprogram the module with Ross tech and get the steering aligned bang on and problem was fixed
  1. Steering angle sensor
    By Caddy2k in forum VCDS - Help Requests
    Last Post: 19-09-2012, 04:45 PM
  2. steering angle sensor? which one?
    By baz_baz in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 14-02-2012, 02:38 AM
  3. G85 fault Steering angle Sensor
    By Pamchico in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 28-01-2012, 07:51 AM
  4. How to program a replacement ABS Controller & Setup G85 Steering Control Sensor???
    By Tecnic91687 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 27-01-2012, 10:56 PM
  5. steering angle sensor
    By dubber dude in forum Audi A3 - 8L - 1996 - 2003
    Last Post: 03-01-2011, 08:45 PM
