Thread: Steering wheel knocking noise
Page 1 of 3 123 LastLast
Results 1 to 10 of 21
  1. Steering wheel knocking noise
    Jul 2012
    United Kingdom
    Over the past few weeks I have a knocking noise when turning the steering wheel at low speeds. Its a pretty noticeable noise that the passenger can hear too. I can also feel the knocking noise (and by feel, i mean it's like someone is tapping on the inside of your hands) while turning the wheel.
    The local garage has checked the bushes and mechanical side of things and they think it could be the electronic power steering pump, but they don't have the kit to verify. It just started up out of nowhere, no collisions or anything.
    Is the power steering pump a common failure on the b8? The car has only done 34k miles. Any ideas as to what else it could be, bearing in mind its not the bushes, springs e.t.c.. The steering itself feels fine.
    Finally, can anyone recommend a local indie who could check the power steering pump in Manchester, who would also use genuine parts? Otherwise, a trip to Audi it is.
  2. Re: Steering wheel knocking noise
    Apr 2010
    Ashford, Middlesex
    Mine has done this since I got it - almost like a juddering/chattering from the steering column when turning the wheel at very low speeds (in and out of parking spaces for example) - I don't think its a fault as such, but rather a symptom of the electric power steering trying to second guess the pressure that is being exerted against it by the friction at the wheels? My thinking is that a conventional, hydraulic system wouldn't display this as it would simply continue to push the fluid around as requested - my understanding of the electric system is that it checks and adjusts according to the road speed and presumably the friction at the road wheels.
    Lang may yer lum reek!
    Current: '09 Audi A4 Avant SE TDI (143)
    Previous: '56 VW Passat 2.0TDI SE - I survived 'BKP' ownership!
  3. Re: Steering wheel knocking noise
    Jul 2012
    United Kingdom
    Quote Originally Posted by fat controller View Post
    Hi, the noise i get isn't a constant juddering (something i refer to as dry steering). I get that noise too since I've had the car and not worried about it i.e when pulling in and out of parking spaces like you mentioned.
    This knocking noise is new and definitely not normal. I also get it at speeds of around 20mph, when turning a corner. I would try and get a video but the cars moving so difficult. The mechanic definitely thought it wasn't normal. The best way to describe it is a loud knocking noise at continuous intervals when turning the wheel. Almost as if something is knocking into something else
  4. Re: Steering wheel knocking noise
    Apr 2010
    Ashford, Middlesex
    Ah, that sounds different then - I would be inclined to take it to a dealer and see what they say
    Sent from my GT-I9300 using Tapatalk
  5. Re: Steering wheel knocking noise
    Mar 2009
    Brighton
    I'm getting issues too.
    At low speeds and only when the car has been driven a while (i.e. up to full temp), I get a distinct knock/thud reverberating through the steering wheel rim and I can also feel it through my heels. This happens at anything below 20mph or so as the steering wheel passes through the 2 o'clock and 10 o'clock positions from centre.
    The dull knock/thud sound is not loud, I can feel it more than I can hear it.
    I'm waiting for my local dealer to call me back and have spoken to Audi UK. There are no TSB's or Recalls relating to this issue I'm told.
    Any ideas what this could be? Anyone else experienced this and found the cause?
    Mine's a 2010 MY and so has hydraulic PAS.
    Embisix
    Current: 2010 A4 2.0TDI Quattro S line Executive Saloon (Sepang Blue Pearl)
    Previous: 2004 A4 Avant 1.9 TDI Quattro Sport (Atlas Grey)
    Previous: A string of (mainly) DOHC VTEC flavoured Hondas
  6. Re: Steering wheel knocking noise
    Jul 2012
    United Kingdom
    Quote Originally Posted by Embisix View Post
    Mine is also a 2010 but I've not taken mine to the main dealer yet as it's not persistent enough to demonstrate. I was told by a mechanic it could be the electric steering pump (which alone costs £500) but I've not had this confirmed by dealer. The symptoms on my car sound similar to yours but they happen regardless of temp with the addition that even the passenger can hear the sound. If you do find out what the issue is with your car, please update us on here. Would be interesting to know.
  7. Re: Steering wheel knocking noise
    Aug 2012
    Orpington
    Quote Originally Posted by _tones View Post
    Had similar issue on mine - turned out to be steering column
  8. Re: Steering wheel knocking noise
    Sep 2012
    Scunthorpe
    Just had mine serviced at 39,000 miles (Monday the 17th) and it had another steering software update this is the second one now first at 19,000 on its first service.
    Have you had both of these updates?
    Current
    2016 A6 SE ultra
    2005 Suzuki Burgman 400
    2002 Honda Hornet 600F2
    1998 Yamaha YZF600R Thundercat
  9. Re: Steering wheel knocking noise
    Mar 2009
    Brighton
    Mine's pretty consistent so I'm confident I'll be able to get the mechanic to experience it. What I'm afraid of is being billed a small fortune just to find out what it 'might' be. Hopefully they'll have come across this before and go, "oh yeah mate, that's yer spigot half-spline dubrey wotsit! We can sort it for a fiver and we'll wash yer car while it's in"..... And then I woke up!
    As and when I find out anything, you can be sure it'll be posted right here! Watch this space....
    Embisix
  10. Re: Steering wheel knocking noise
    Feb 2016
    slovakia
    Hi Embisix, have you found the issue, please?
  1. Knocking noise when steering
    By mark- in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 09-11-2010, 05:01 PM
  2. knocking from steering wheel
    By r3ahj in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 25-11-2009, 09:41 PM
  3. Knocking when turning steering wheel!
    By Simpsvag in forum Passat - B5 Forum - 1997 -2005
    Last Post: 09-08-2009, 08:24 PM
  4. Knocking noise when steering
    By Audoman in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-11-2008, 08:55 PM
  5. Knocking noise when steering
    By kevwall in forum Golf MK4 - 1999 - 2004
    Last Post: 06-04-2008, 08:24 PM
