Thread: VCDS Tricks for the A7
Page 12 of 18 FirstFirst ... 21011121314 ... LastLast
Results 111 to 120 of 175
  1. Re: VCDS Tricks for the A7
    Mar 2017
    Oakham
    Cheers buddyboy.
    I assume the cheap ones on ebay are Read-only?
    Cheers.
  2. Re: VCDS Tricks for the A7
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I doubt they would work with vcds software so they would be a waste of money. You can get an obdeleven bluetooth dongle which give you the ability to code most features, check and clear codes but its not as user friendly as VCDS
  3. Re: VCDS Tricks for the A7
    Mar 2017
    Oakham
    Ok so tried to do some coding tonight with friends VCDS and wanted to add needle sweep and boot close with key fob. Followed the instructions on here and neither option was available in the Long Code Helper. Any help appreciated. The below is what was in the LC Helper:
  4. Re: VCDS Tricks for the A7
    Feb 2013
    Gloucester
    57 Post(s)
    The boot coding isn't done in the long coding helper. It's done in adaptation (from memory).
    The rest should work though, where you have the alpha numeric code in green in the boxes below the big number I yellow. Click in each one and the list of options you can activate changes. It also changes the wording on the left (byte 0, byte 1 etc etc)
    Does that help?
    Sent from my iPhone using Tapatalk Pro
  5. Re: VCDS Tricks for the A7
    Mar 2017
    Oakham
    Quote Originally Posted by M1tchy View Post
    Does that help?
    Nailed it. Cheers.
    You any good are reading error logs? I can't get my head around it.
  6. Re: VCDS Tricks for the A7
    Feb 2013
    Gloucester
    57 Post(s)
    I think I'm ok. At least I can get what I've needed to from them. Send me a copy or post it up and I'll try to help
  7. Re: VCDS Tricks for the A7
    Mar 2017
    Oakham
    You're a legend, cheers.
    Rob
    Chassis Type: 4G (4G0)
    Scan: 01 02 03 05 08 09 10 15 16 17 19 28 30 36 3B 42 44 46 47 52
    53 55 56 5F 62 69 6D 72 82 A9 C0
    VIN: WAUZZZ4G7EN039359 Mileage: 163534km-101615miles
    01-Engine -- Status: OK 0000
    02-Auto Trans -- Status: OK 0000
    05-Acc/Start Auth. -- Status: OK 0000
    10-Park/Steer Assist -- Status: OK 0000
    15-Airbags -- Status: OK 0000
    28-HVAC, Rear -- Status: Malfunction 0010
    30-Special Function II -- Status: OK 0000
    36-Seat Mem. Drvr -- Status: OK 0000
    3B-Sensor Elect. -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    53-Parking Brake -- Status: OK 0000
    55-Headlight Range -- Status: OK 0000
    56-Radio -- Status: OK 0000
    5F-Information Electr. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6D-Trunk Elect. -- Status: OK 0000
    82-Heads Up Display -- Status: OK 0000
    A9-Struct. Borne Sound -- Status: OK 0000
    C0-Act. for Ext. Noise -- Status: OK 0000
    Address 03: ABS Brakes (J104) Labels: 4G0-907-379-V1.clb
    Part No SW: 4G0 907 379 L HW: 4G0 907 379 L
    Component: ESP PREMIUM H09 0450
    Revision: -------- Serial number: --------------
    Coding: 49A79F0392E5F9C0FB00
    Shop #: WSC 63665 000 1048576
    ASAM Dataset: EV_ESPPremiAU57X 004039
    ROD: EV_ESPPremiAU57X_004_AU57.rod
    VCID: 3A7FC069BDEBC791E7-806E
    1 Fault Found:
    0604 - Tire Pressure Warning
    C102D 00 [008] - -
    Intermittent - Confirmed - Tested Since Memory Clear
    Freeze Frame:
    Fault Status: 00000001
    Fault Priority: 2
    Fault Frequency: 3
    Reset counter: 76
    Mileage: 163159 km
    Date: 2017.04.18
    Time: 07:16:48
    VzRef: 3E
    Bit Info 1: 00
    Bit Info 2: 40
    Bit Info 3: 26
    Bit Info 4: 1F
    F-Path: 01
    F-Type: 2C
    Uz: BC
    Address 08: Auto HVAC (J255) Labels: 4G0-820-043-4Z.clb
    Part No SW: 4G0 820 043 AE HW: 4G0 820 043 AE
    Component: KLIMA 4 ZONEN H13 0087
    Serial number: 19071300041082
    Coding: 362300B831
    Shop #: WSC 02391 785 00200
    ASAM Dataset: EV_AirCondiComfoUDS 002040
    ROD: EV_AirCondiComfoUDS_002.rod
    VCID: 62CF580975FBEF519F-8036
    1 Fault Found:
    0035 - Motor for Recirculation Flap
    B1092 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 3
    Fault Frequency: 26
    Reset counter: 70
    Mileage: 146746 km
    Date: 2016.10.10
    Time: 12:24:24
    Voltage terminal 30: 13.35 V
    Outside air temperature: 17.0 °C
    Interior temperature: 21.29 °C
    Recirculation flap motor-Act.value: 10335
    Recirculation flap motor-Specified value: 11744
    Recirculation flap motor-Stop open: 11443
    Recirculation flap motor-Stop closed: 10000
    Address 09: Cent. Elect. (J519) Labels: 4H0-907-063-V1.clb
    Part No SW: 4H0 907 063 CF HW: 4H0 907 063 F
    Component: BCM1 2.0 H12 0130
    Revision: 20012002 Serial number: 00000001454220
    Coding: 2600201040349FE0018100C3A0001D0CCF9DE30A2709020100 0008606100
    VCID: 6ED73C39B9235B310B-803A
    Subsystem 1 - Part No SW: 4G2 955 119 HW: 4G8 955 119 A Labels: 1KX-955-119.CLB
    Component: WWS57X 130709 H36 0080
    Serial number: 130710193639
    Coding: 0045F7
    Subsystem 2 - Part No SW: 8U0 955 559 B HW: 8U0 955 559 B Labels: 8U0-955-559.CLB
    Component: G397_RLFS H06 0002
    Serial number: 21561054
    Coding: 02006E
    Subsystem 3 - Part No SW: 4G0 941 531 AA HW: 4G0 941 531 AA
    Component: E1 - LDS H07 0044
    Serial number: 17 07 2013 00000882
    Subsystem 4 - Part No SW: 4H0 907 658 HW: 4H0 907 658
    Component: AQ_Hum_Sensor H03 0003
    Serial number: EC698AB6000000000001
    1 Fault Found:
    01320 - Control Module for Climatronic (J255)
    013 - Check DTC Memory - Intermittent
    Freeze Frame:
    Fault Status: 00101101
    Fault Priority: 6
    Fault Frequency: 26
    Reset counter: 70
    Mileage: 146746 km
    Time Indication: 0
    Date: 2016.10.10
    Time: 12:24:00
    Address 17: Instruments (J285) Labels: 4H0-920-xxx-17.clb
    Part No SW: 4G8 920 984 H HW: 4G8 920 984 H
    Component: TDieGb H80 0618
    Revision: 30460230 Serial number: 658230713596007
    Coding: 33A600020B432600010100
    ASAM Dataset: EV_RBD4K 004048
    ROD: EV_RBD4K.rod
    VCID: 3B71C56DB2D1FE99FC-806E
    1 Fault Found:
    1048578 - No Basic Setting
    B2010 00 [009] - -
    Freeze Frame:
    Fault Priority: 6
    Fault Frequency: 1
    Reset counter: 15
    Mileage: 144896 km
    Date: 2016.09.27
    Time: 10:19:51
    Address 28: HVAC, Rear (E265) Labels: 4G0-919-158.clb
    Part No SW: 4G0 919 158 K HW: 4G0 919 158 K
    Component: KLIMA FOND H07 0087
    Serial number: 17071300040057
    Coding: 22
    ASAM Dataset: EV_ClimaContrUnitRearUDS 002019
    ROD: EV_ClimaContrUnitRearUDS_002.rod
    VCID: 3779D95D8EF9DAF918-8062
    1 Fault Found:
    0075 - Button or Switch in Operating Unit
    B10C7 07 [008] - Mechanical Failure
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 5
    Reset counter: 60
    Mileage: 161934 km
    Date: 2017.03.05
    Time: 10:25:17
    Outside air temperature: 4.5 °C
    Left rear vent temperature: 8.4 °C
    Address 46: Central Conv. (J393) Labels: 4H0-907-064-46.clb
    Part No SW: 4H0 907 064 DN HW: 4H0 907 064 DN
    Component: BCM2 2.0 H35 0510
    Revision: 00002001 Serial number: 0311940898
    Coding: 013B0622A0B9B88083200A8420010D47000000000000000000 0000000000
    VCID: 78FB1A61CB671581D1-802C
    Subsystem 1 - Part No: 4G0 951 177
    Component: DWA-Sensor H01 0010
    Subsystem 2 - Part No: 1K0 951 605 C
    Component: LIN BACKUP HO H05 1501
    Subsystem 3 - Part No SW: 4G0 947 135 B HW: 4G0 947 135
    Component: Dachelektroni H10 0100
    Serial number: 0000000AP00004073120
    Coding: 010000
    Subsystem 4 - Part No SW: 4G8 959 252 HW: 4G8 959 252
    Component: HSP-SG H11 0029
    Serial number: WA107414000004065595
    2 Faults Found:
    02615 - Fuel Tank Cap; Lock
    009 - Open or Short to Ground
    Freeze Frame:
    Fault Status: 01101001
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 16
    Mileage: 144898 km
    Time Indication: 0
    Date: 2016.09.27
    Time: 10:45:01
    02616 - Fuel Tank Cap; Unlock
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 16
    Mileage: 144898 km
    Time Indication: 0
    Date: 2016.09.27
    Time: 10:45:01
    End-------------------------(Elapsed Time: 06:17)--------------------------
  8. Re: VCDS Tricks for the A7
    Feb 2016
    Hungary
    113 Post(s)
    Just a short info:
    Today I've just made the MMI Version 942_4 upgrade in a local garage, but honestly I didn't found any difference between the new and the former MMI 770 version.
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  9. VCDS Tricks for the A7
    Feb 2013
    Gloucester
    57 Post(s)
    So most of those occourred on 10/10/16 or a few weeks earlier on 27/09/16.
    The fault frequency is 1.
    So I would suggest that someone was doing something to the car on the earlier date, finished it off in the second date and didn't isolate the power. This will cause surges etc around the circuit giving the faults. The fact they have only occurred once seems to back this up too.
    I would clear all faults and rescan and if I were a betting man I'd bet they won't return.
    The fault from address 28 HVAC (heating, ventilation and air con) is the only one that doesn't fit with the above. Again though if you reset it and it returns, it will confirm there is a fault and can be looked into.
  10. Re: VCDS Tricks for the A7
    Nov 2015
    Dublin, Ireland
    7 Post(s)
    I think those aircon faults occured when you have the aircon control unit disconnected below the MMI, that might have been taken out in the past from some reason and codes not cleared. I had similar on mine recently when i was trying the rear view camera retrofit. copy the logs and clear them and deal with whatever comes back
  1. A6 C7 VCDS Tricks
    By MFGF in forum Audi A6 - C7 Forum - 2011- 2018
    Last Post: 18-03-2024, 10:39 AM
  2. Audi A4 B8 - VAG.com Tricks
    By 73kingstonroad in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 08-03-2021, 05:34 PM
  3. How To Tricks of the trade
    By eonbkuk in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 20-07-2013, 01:40 PM
  4. Audi A6 Tricks ??????????????
    By slice636 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 28-10-2009, 12:27 PM
  5. Question vag com tricks?
    By andymartin045 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 06-09-2009, 07:43 PM
