Thread: Rear parking sensor plug- where is it?
Results 1 to 10 of 11
  1. Rear parking sensor plug- where is it?
    Jul 2013
    Braintree UK
    So I've just had my Westfalia towbar delivered from PFJones and I've almost got the bumper off. The first issue I've run into is trying to disconnect the (factory) parking sensor loom. It's cable tied along the inside of the bumper and I've followed the cable through the grommet into the right corner and up above the rear light where it goes forwards. However I was hoping to unplug it to prevent any damage, anyone know where the plug is?
  2. Re: Rear parking sensor plug- where is it?
    46 Post(s)
    OEM sensors or aftermarket?
    Saloon or Avant?
    Why not just unplug each sensor if that would help?
  3. Re: Rear parking sensor plug- where is it?
    Jul 2013
    76 Post(s)
    In the right hand wheel well, just pop off spare wheel tool cover and it is sitting on the wheel arch.
  4. Re: Rear parking sensor plug- where is it?
    Jul 2013
    Braintree UK
    Thanks Dan, I'll look again in the morning. I traced it all the way from the grommet towards the front and I can't see anything. I guess I could unplug each sensor but I'm worried I'll break a clip seeing as it's about 2°C outside.
  5. Re: Rear parking sensor plug- where is it?
    46 Post(s)
    Quote Originally Posted by Happybiker View Post
    Saloon or Avant?
    If you told us the above I can direct you to the PDC module if OEM.
  6. Re: Rear parking sensor plug- where is it?
    Jul 2013
    Braintree UK
    It's an OEM system on a 2008 saloon. I'll try again when it's light.
  7. Re: Rear parking sensor plug- where is it?
    Jul 2013
    76 Post(s)
    His OP did say factory fit.
  8. Re: Rear parking sensor plug- where is it?
    46 Post(s)
    Quote Originally Posted by dan2485 View Post
    Audi supply "factory" fit aftermarket kits so just making sure!
  9. Re: Rear parking sensor plug- where is it?
    Jul 2013
    Braintree UK
    I never found a plug, just unclipped all the sensors which was fairly easy. The same can't be said fit fitting the towbar, it took most of the day!
  10. Re: Rear parking sensor plug- where is it?
    Aug 2019
    Stavanger
    I bought a A6 C6 Avant with aftermarket parking sensors (rear). They didn't install a relay so I get every 30 seconds a beep (check bulb I assume). Does anyone here have a proper connection diagram for wiring such an aftermarket kit (the standard cheapo eBay one)? Thanks and much appreciated.
    Cheers,
    Mark
    By dylel in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 18-12-2011, 10:11 PM
  2. Parking sensor (rear)
    By pete99 in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 30-08-2011, 08:43 AM
  3. Parking Sensor Plug Location
    By Little Old Me in forum Touran - Sharan - Caravelle
    Last Post: 15-04-2011, 11:26 PM
  4. Rear parking sensor
    By Stu Thomas in forum Audi A3 - Archive Topics
    Last Post: 03-03-2009, 10:02 PM
  5. Replies: 1
    Last Post: 31-07-2008, 06:33 AM
