Thread: Q7 not starting...HELP
Results 1 to 8 of 8
  1. Q7 not starting...HELP
    Apr 2010
    Surrey
    23 Post(s)
    My Q7 has a problem. It won't start.
    Its been parked for 3 weeks.
    I have tried jumping it, had the jump leads on for about 1 min from a started car, and couldn't get a response, from the Q7.
    When I turn the key, there is nothing, nothing on the dash, Not turning over, no lights on dash, no pre heater lights, no dis, only thing that comes on is the radio!...however, the central locking, courtesy lighting, power boot etc work fine. This leads me to believe it is not the Battery. The battery has been replaced about a year ago.
    I think it is the ignition switch, what do you guys think?....I have VAGCOM'd it, heres the results:
    Mileage: 105940km-65828mi Repair Order:
    Chassis Type: 4L0
    Scan: 01 02 03 05 07 08 09 0E 15 16 17 18 19 34 37 42 46 47 4F 52
    56 61 62 69 6C 6D 6F 72 76
    Mileage: 105940km/65828miles
    00-Steering Angle Sensor -- Status: Cannot be reached 1100
    01-Engine -- Status: Cannot be reached 1100
    02-Auto Trans -- Status: Cannot be reached 1100
    03-ABS Brakes -- Status: Cannot be reached 1100
    05-Acc/Start Auth. -- Status: Malfunction 0010
    07-Control Head -- Status: OK 0000
    0E-Media Player 1 -- Status: Malfunction 0010
    15-Airbags -- Status: Cannot be reached 1100
    18-Aux. Heat -- Status: Malfunction 0010
    34-Level Control -- Status: Cannot be reached 1100
    37-Navigation -- Status: OK 0000
    47-Sound System -- Status: OK 0000
    4F-Centr. Electr. II -- Status: OK 0000
    56-Radio -- Status: OK 0000
    61-Battery Regul. -- Status: OK 0000
    69-Trailer -- Status: OK 0000
    6C-Back-up Cam. -- Status: Malfunction 0010
    6D-Trunk Elect. -- Status: OK 0000
    6F-Centr. Conv. II -- Status: OK 0000
    76-Park Assist -- Status: OK 0000
    Address 01: Engine
    Cannot be reached
    Address 02: Auto Trans
    Cannot be reached
    Address 03: ABS Brakes
    Cannot be reached
    Address 05: Acc/Start Auth. Labels: 4F0-910-852.clb
    Part No SW: 4F0 910 852 HW: 4F0 905 852 B
    Component: FBSAUDIC6 ELV H31 0220
    Revision: 31050601 Serial number: 10601000509699
    Coding: 0000147
    Shop #: WSC 31414 790 00001
    VCID: E3CF02EA22E10106691-80B6
    Subsystem 1 - Part No: 4F0 910 131 E
    Component: FBSAUDIC6 EZS H45 0080
    Subsystem 2 - Part No: 4F0 910 220 D
    Component: FBSAUDIC6 IDG H01 0040
    2 Faults Found:
    00288 - Steering Column Lock Actuator (N360)
    014 - Defective
    Freeze Frame:
    Fault Status: 01111110
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 184
    Mileage: 105948 km
    Time Indication: 0
    Date: 2014.01.18
    Time: 08:45:33
    01176 - Key
    Freeze Frame:
    Fault Status: 00100100
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 105948 km
    Time Indication: 0
    Date: 2014.01.19
    Time: 20:01:35
    Address 07: Control Head Labels: 4L0-910-7xx-07-H.lbl
    Part No SW: 4L1 910 732 H HW: 4E0 035 729 A
    Component: Interfacebox H43 5570
    Revision: 00000000 Serial number: 387HS067521351
    Coding: 0002002
    VCID: 2F673EDABEA975663D9-807A
    Subsystem 1 - Part No: 4L0 910 609
    Component: E0380 BedienteilH01 0060
    Subsystem 2 - Serial number: 00000001115253
    Subsystem 3 - Serial number: 0130.06.080000000100010531’
    Subsystem 4 - Serial number: 010531’
    No fault code found.
    Address 08: Auto HVAC Labels: None
    Part No SW: 4L0 910 043 HW: 4L0 820 043 F
    Component: KLIMABETAETIGUNGH05 0060
    Revision: 00---009 Serial number: 00000000063946
    Coding: 0001046
    VCID: E1C308E238FD13167BD-80B4
    1 Fault Found:
    00712 - Right Footwell Flap Positioning Motor (V109)
    003 - Mechanical Failure - Intermittent
    Freeze Frame:
    Fault Status: 00100011
    Fault Priority: 3
    Fault Frequency: 72
    Reset counter: 224
    Mileage: 102084 km
    Time Indication: 0
    Date: 2013.08.08
    Time: 00:06:53
    Freeze Frame:
    Voltage: 14.00 V
    Temperature: 26.0°C
    (no units): 132.0
    (no units): 140.0
    Temperature: 11.0°C
    Address 09: Cent. Elect. Labels: 4F0-910-279.lbl
    Part No SW: 4F0 910 279 K HW: 4F0 907 279
    Component: ILM Fahrer H17 0240
    Revision: 00000000 Serial number: 4F0907279
    Coding: 0010101
    VCID: 316338A2A89D63962BD-8064
    Subsystem 1 - Component: Fehler Lin-Slave 01
    Subsystem 2 - Component: Fehler Lin-Slave 02
    Address 0E: Media Player 1 Labels: 4E0-910-111.lbl
    Part No SW: 4L0 910 111 A HW: 4L0 035 111
    Component: CD-Changer H41 0100
    Revision: 00000000 Serial number: AUZ5ZBF3038414
    Shop #: WSC 00000 000 00000
    VCID: 1E39F31EC903ECEE86F-804B
    1 Fault Found:
    02261 - Data Medium
    014 - Defective - Intermittent
    Freeze Frame:
    Fault Status: 00101110
    Fault Priority: 7
    Fault Frequency: 9
    Reset counter: 199
    Mileage: 104293 km
    Time Indication: 0
    Date: 2013.11.08
    Time: 21:15:46
    Freeze Frame:
    Text: 00000510
    Address 15: Airbags
    Cannot be reached
    Address 16: Steering wheel Labels: 4F0-910-549.lbl
    Part No SW: 4F0 910 549 HW: 4F0 953 549 A
    Component: Lenksäulenmodul H08 0230
    Revision: 00H08000 Serial number: 90026061760441
    Coding: 0102042
    VCID: E6C91BFED1D3742E8EF-80B3
    Subsystem 1 - Part No: XXXXXXXXXXX
    Component: Lenkradmodul H07 0090
    Address 17: Instruments Labels: 4L0-910-xxx-17.lbl
    Part No SW: 4F0 910 930 C HW: 4L0 920 980 G
    Component: KOMBIINSTR. M73 H17 0110
    Revision: 00400000 Serial number: 5HJ37KW86
    Coding: 2593413
    Shop #: WSC 00067 210 17516
    VCID: 234FC2EAE261C106A91-8076
    Address 18: Aux. Heat Labels: None
    Part No SW: 4L0 910 105 HW: 4L0 815 071 C
    Component: Heizgeraet H07 0060
    Revision: 0000000E Serial number: 00000009011043
    Coding: 0000002
    VCID: E0C50DE633F71A1E743-80B5
    1 Fault Found:
    00664 - Fuel gauge
    002 - Lower Limit Exceeded
    Address 19: CAN Gateway Labels: 4L0-910-468.lbl
    Part No SW: 4L0 910 468 HW: 4L0 907 468
    Component: J533__Gateway H06 0040
    Revision: 00H06000 Serial number: 0900B06816802F
    Coding: F75BFE5F302202
    Shop #: WSC 00045 210 90242
    VCID: ECDD69D6CF3F4E7ED8B-80B9
    Address 34: Level Control
    Cannot be reached
    Address 37: Navigation Labels: 4E0-910-88x-37.lbl
    Part No SW: 4E0 910 888 P HW: 4E0 919 887 D
    Component: MNS ECE H48 1060
    Revision: 00000000 Serial number: 313GL067504508
    Shop #: WSC 00045 210 83908
    VCID: 3B7F1A8A7AD199C6811-806E
    Address 42: Door Elect, Driver
    Cannot be reached
    Address 46: Central Conv.
    Cannot be reached
    Address 47: Sound System Labels: Redir Fail!
    Part No SW: 4L0 910 223 B HW: 4L0 035 223
    Component: DSP-AU716 H20 0100
    Revision: 12S00001 Serial number: 02008060340649
    Coding: 0000003
    Address 4F: Centr. Electr. II Labels: 4F0-910-280.lbl
    Part No SW: 4F0 910 280 HW: 4F0 907 280 E
    Component: ILM Beifahrer H10 0080
    Revision: Serial number: 00000000007824
    Coding: 0011101
    VCID: DEB9331E09832CEE46F-808B
    Address 52: Door Elect, Pass.
    Cannot be reached
    Address 56: Radio Labels: 4E0-910-541.lbl
    Part No SW: 4E0 910 541 T HW: 4E0 035 541 P
    Component: TUNER EU/US/RDW H42 0630
    Revision: 00000000 Serial number: 388H2067547467
    Coding: 0000001
    Address 61: Battery Regul. Labels: 4F0-910-181.lbl
    Part No SW: 4L0 910 181 HW: 4L0 915 181
    Component: J0644 BEM H12 0530
    Revision: -------- Serial number: 00000000038482
    VCID: E4CD01F627EF063E90B-80B1
    Subsystem 1 - Part No: 4F0 915 105 D
    Component: von VA0 2608212841
    Coding: 344630393135313035442056413032363038323132383431
    Shop #: WSC 31912 037 68319
    Address 62: Door, Rear Left
    Cannot be reached
    Address 69: Trailer Labels: 4E0-910-383.lbl
    Part No SW: 4E0 910 383 C HW: 4E0 907 383 C
    Component: ANHAENGERELEKTR 004 0060
    Coding: 0000001
    VCID: 244DC1F6E76FC63ED0B-8071
    Address 6C: Back-up Cam.
    Cannot be reached
    Address 6D: Trunk Elect. Labels: None
    Part No SW: 4L0 910 945 HW: 4L0 827 851 B
    Component: ValeoHeckdeckel H21 0280
    Revision: --H21001 Serial number: E5030000B
    Shop #: WSC 98765 666 38354
    Subsystem 1 - Part No: 4L0 910 946
    Subsystem 2 - Serial number: E5030100B
    Subsystem 3 - Serial number: RD30.08.06--H21001001C0033’
    Subsystem 4 - Serial number: 1C0033’
    Address 6F: Centr. Conv. II
    Cannot be reached
    Address 72: Door, Rear Right
    Cannot be reached
    Address 76: Park Assist Labels: 4Fx-910-283.lbl
    Part No SW: 4F0 910 283 G HW: 4F0 919 283 G
    Component: Parkhilfe 8-Kan H12 0060
    Revision: 00H12000 Serial number: 06320620902707
    Coding: 0231046
    VCID: 2855D5C69B47225EFC3-807D
    Most of the modules cannot be reached due to the ignition not turning on....anyone suggest any easy fixes, or checks?
    Thanks,
    Manny
  2. Re: Q7 not starting...HELP
    46 Post(s)
    If you told us the engine we might be able to advise a bit better.
    Have you checked fuses?
    Coding: 0000147
    2 Faults Found:
    014 - Defective
    Freeze Frame:
    Fault Priority: 1
    Fault Frequency: 1
    Reset counter: 184
    Mileage: 105948 km
    Time Indication: 0
    Date: 2014.01.18
    Time: 08:45:33
    01176 - Key
    Freeze Frame:
    Fault Priority: 2
    Fault Frequency: 1
    Reset counter: 224
    Mileage: 105948 km
    Time Indication: 0
    Date: 2014.01.19
    Time: 20:01:35
    If you are using a geniune cable you can contact Rosstech.
  3. Re: Q7 not starting...HELP
    Apr 2010
    Surrey
    23 Post(s)
    Hi Chris, Its a Q7, 3.0 tdi, Haven't checked any fuses yet.
  4. Re: Q7 not starting...HELP
    46 Post(s)
    Check them and report back.
    Contact Ross Tech for advise also if you're using a genuine cable and send them the fault codes.
  5. Re: Q7 not starting...HELP
    Apr 2010
    Surrey
    23 Post(s)
    I am using a genuine cable....I wasn't aware Ross tech would advise on whats wrong with my car.
  6. Re: Q7 not starting...HELP
    46 Post(s)
    Oh yes, genuine users avail of free technical/mechanical support from RT themselves.
    Have a read through this Ross-Tech: VCDS: Support
  7. Re: Q7 not starting...HELP
    Did you find a fix for this? I have the same problem, i suspect its probably the steering lock actuator (expensive part).
    For me i get that same error about steering actuator.
    Dash is dead, MMI works. Tried to start car and nothing. I ran a scan with VCDS and cleared faults, then ran a new scan and half way through the scan the ignition comes on and i can start the car.
    I drove 5 miles and stopped for 20 mins and same problem. Ran scan/erase/scan again and car starts.
  8. Re: Q7 not starting...HELP
    Apr 2010
    Surrey
    23 Post(s)
    Wow, this is an old thread being resurrected.
    My fix according to Audi was a dead ignition switch, total cost was £1500 from Audi.
    Mine was completely dead, your problem is different.
  1. non starting A4
    By Geminslayer in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 23-03-2013, 02:46 PM
  2. Starting motor? Not starting
    By Trademark2k6 in forum Golf MK5 - 2004 - 2009
    Last Post: 28-12-2010, 11:57 PM
  3. Not starting
    By stevemr in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 25-11-2010, 02:04 AM
  4. a6 starting
    By charlee123 in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 07-07-2008, 09:49 PM
  5. Help with non starting A4 2.8
    By joca in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 09-03-2008, 10:11 AM
