Thread: scan tool reading everything except the ECU.?
  1. scan tool reading everything except the ECU.?
    Jan 2014
    Australia
    Hi there,
    I have a 1998 2.5 petrol T4 with a starting issue.(which has been unable to be diagnosed for 8 weeks now by previous mechanics including the dealership)
    I have finally found a mechanic who is able to scan the vehicle.!!
    The only drama i have now is that he is able to scan/read the whole vehicle except for the ECU.
    He suggested it is more than likely an "earthing" problem, which he is waiting on a wiring diagram before commences work.
    If anyone has come across this before or has any suggestions why the ECU is not being picked up on the scan, please feel free to comment.
    Many thanks.
    J.
  2. Re: scan tool reading everything except the ECU.?
    Apr 2013
    Kent
    What scan tool is he using?
  3. Re: scan tool reading everything except the ECU.?
    Jan 2014
    Australia
    hi Avidfanofstuff
    not sure, will find out.
    cheers,
  4. Re: scan tool reading everything except the ECU.?
    May 2012
    Notts UK
    Ask him to check measuring block values within the cluster module. Check channel 125. This shows communication status to other modules. See if it sees the ecu. check fuses. Usually when the module goes bad it blocks other comms until removed
    Moderator edit:
    If you wish to advertise your services please contact Stuart for prices on Sponsor packages. - VWAF - Rules on Advertising
  1. Please Help VGATE VS450 scan tool wont connect with car
    By battmiceter in forum Audi A4 - B8 Forum - 2008 - 2015
    Last Post: 25-12-2012, 10:39 PM
  2. Reading ECU Faults
    By needhelp in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 26-02-2012, 09:26 PM
  3. Rear reading reading lights not working
    By Daftbrush in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 12-07-2011, 07:27 AM
  4. VW tool ECU recode 1993 Polo GT (Digifant)
    By schneil in forum Vehicle Diagnostics Equipment- Except VCDS
    Last Post: 30-12-2010, 12:07 AM
  5. OBD scan tool will not scan 98 jetta 2.0 (bora uk)
    By Romb4557 in forum Bora - 1998 - 2005
    Last Post: 17-01-2007, 05:29 AM
