Thread: Intermittent climate/fan issues
Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
  1. Re: Intermittent climate/fan issues
    #11
    Aug 2007
    Sale (Manchester)
    I've tagged onto this old thread (rather than starting a new one) as it contains relevant information.
    On short journey's I find that that my blower motor wouldn't work. On very long journeys I'd find it suddenly starts working randomly for short periods. I can also hearing it starting to spool up then failing.
    A local garage have replaced the blower resistor 4F0820521 / 4F0820521A (I'm unsure which). That didn't work.
    They attached voltage straight to the fan motor and it spools up and runs absolutely fine. This leads them to believe it's the actual climate control unit at fault: 4F0910043J
    Whilst these are only £40 to buy second hand, apparently they can ONLY be re-coded by the dealership for some reason (not possible at an Indie supposedly). Can anybody confirm if this is the case?
    I'm having a lot of trouble finding a dealership who's willing to re-code a second-hand part (unsurprisingly) The new part is £1,110 + re-coding + VAT!! Considering I've just replaced all 6 injectors - it's more than I can afford to spend.
    Because it was only £14, I've also ordered another part for the garage to try that may help & hopefully won't need to be re-coded - Audi A6 C6 Control Unit for Convenience System ECU: 4F0907289G
    Can anybody who's had similar troubles offer me any advice or their experience please?
    Al.
    [ Current Cars: 2006 A6 S-Line 3.0 V6 TDI Quattro Avant | 2007 VW Touran 2.0 TDI DSG ]
    [ Past Audis: A4 3.0 V6 TDI Quattro S-Line Saloon | S6 4.2 Quattro Saloon | A4 2.5 V6 TDI Quattro Sport Saloon | A4 1.9 TDI Quattro Avant S-Line ]
    [ Past Golfs: Mk1 GTI Cabrio | Mk3 2.0 Cabrio | Mk3 VR6 | Mk4 R32 | Mk4 V6 MoFo | Mk4 Golf 1.9 TDI SE Auto | Mk4 Supercharged 2.0 GTI 6-speed ]
  2. Re: Intermittent climate/fan issues
    #12
    Jul 2013
    39 Post(s)
    There are independents that can remove the Componet Protection for around £80.
    Ask your garage to check that the motor leads are connecting correctly to the resistor module.
    Are getting the V2 blower open/close circuit fault code?
    Dan
    2009/2010 2.0 TDIe SE
  3. Re: Intermittent climate/fan issues
    #13
    Jul 2013
    39 Post(s)
    Be careful when swapping the modules as you can force the modules to go into CP mode.
    Dan
  4. Intermittent climate/fan issues
    #14
    Aug 2007
    Sale (Manchester)
    Thanks very much for your input Dan, I will ask the garage to confirm re: the motor / resistor cables and the V2 blower error state.
    The control module (with the 2 dials / 2 LED matrix displays) has already been disconnected & reconnected. What would it display on its LED display if it had gone into Content Protection mode please?
    Al
  5. Re: Intermittent climate/fan issues
    #15
    Aug 2007
    Sale (Manchester)
    Quote Originally Posted by dan2485 View Post
    Does anybody know of a specialist in the north (Manchester or Leeds etc) that could assist with this please (or is it against forum rules to list independents that can do CP removal?)
    I realise there's a whole ethical debate about how CP is there to deter our cars being stolen and sold for parts!
    Whilst in my case, it's a 13 year old car with hundreds of similar models lining the scrap yards around the country; I suppose listing companies that can remove CP would apply to new models too!
    Al
  6. Re: Intermittent climate/fan issues
    #16
    Jul 2013
    39 Post(s)
    When in the CP mode the unit will function with limited functionality the demist may work correctly as this would be classed as safety issue but the other functions may not work or only work for a few seconds at a time.
    Dan
  7. Re: Intermittent climate/fan issues
    #17
    Aug 2007
    Sale (Manchester)
    Thanks for this info. At the very least, this means we can check the fan runs properly for a few days (using the demister) before going to the expense of having the CP removed!
    Regards
    Al
  8. Re: Intermittent climate/fan issues
    #18
    Aug 2007
    Sale (Manchester)
    Having gone to the expense of getting a replacement aircon control, taking it to an specialist independent who was unable to sort the component protection (surprise surprise!) the garage have been advised thatís itís probably just loose cabling or connectors...
    Of course they have already ensured all connectors are pushed together properly etc
    An auto electrician is coming to inspect the wiring loom for the blower etc...
    In the mean time, the blower continues to go on and off as it pleases during journeys! Not good on these freezing cold nights!
    Al
  9. Re: Intermittent climate/fan issues
    #19
    Jul 2013
    39 Post(s)
    Do You still have the old blower motor on the car as the fault will be the brushes being worn.
    The springs are bouncing hence the sporodic operation as they are now nearing the relaxed state.
    Don’t bother with the electrician just replace the blower motor.
    ECP £89.10 with discount code ‘save55’ until midnight.
    Dan
  10. Re: Intermittent climate/fan issues
    #20
    Aug 2007
    Sale (Manchester)
    Donít bother with the electrician just replace the blower motor.
    ECP £89.10 with discount code Ďsave55í until midnight.
    I the motor wasnít changed because it ran fine when they applied power directly to it...
    But obviously that could be because theyíd jiggled it getting it out of its housing!
    Thanks - itís worth replacing the blower; Iíll give it a go...
    Al
  1. B5 climate fan not working
    By Grover2000 in forum VCDS - Help Requests
    Last Post: 02-07-2011, 09:20 PM
  2. Please Help Climate control- intermittent issue
    By reevelee in forum Golf MK5 - 2004 - 2009
    Last Post: 01-08-2010, 08:44 PM
  3. 04 A3 Climate Control Fan Stuck On
    By PaulA3 in forum Audi A3 - Archive Topics
    Last Post: 08-09-2007, 10:55 PM
  4. Blower Fan Intermittent
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2007, 07:01 PM
  5. Climate Control Display Intermittent
    By oakhills5093 in forum Archive posts
    Last Post: 06-02-2007, 10:28 PM
