Thread: Intermittent climate/fan issues
Results 1 to 10 of 20
  1. Intermittent climate/fan issues
    Nov 2010
    Middle of nowhere
    Several times over the past month I noticed upon starting the car the windscreen de-mist would not work. The light would come on when the button was pressed but no fan action. Depending upon the journey time, it might work if I pressed it later on but not always. Also upon subsequent investigation I found the car would take longer than normal to heat up if this occurred as the fans didn't appear to be blowing at all & changing the fan speed on the dash had no effect.
    The rest of the time, fans work as normal & car heats up as expected.
    Haven't got access to VCDS yet to scan for fault codes (still waiting for VCDS Mobile to be released! )
    Could it be a dodgy sensor somewhere or faulty fan? Pollen filters were changed a couple of months back so should be clear.
    Facelift A6 2.0 170 TDI Avant
  2. Re: Intermittent climate/fan issues
    Feb 2013
    Gloucester
    45 Post(s)
    Is there anyone near that could scan for you?
    Sent from my iPad using Tapatalk HD
  3. Re: Intermittent climate/fan issues
    43 Post(s)
  4. Re: Intermittent climate/fan issues
    Nov 2010
    Middle of nowhere
    Got a scan done today by a friend with VCDS and it churned out 01273 - Fresh Air Blower (V2) - 009 Open or Short to ground.
    We did a diagnostics of the various flap motors and they were ok but when it got to the blower it increased the voltage but no sound from the blower.
    Weirdly though the fan will work if it is cold (i.e. on first start in the morning), if I get back in later however though it won't work which suggests its temperature related.
    I can't seem to find if mine (59 facelift) has a thermal resistor like older vehicles or if it is just a blower with control unit attached. Crasher had some useful info in this post I found:
    "01273" fault code, part code descriptions.
    Am I right in thinking the blower unit is in the plenum chamber ?
  5. Re: Intermittent climate/fan issues
    Jul 2013
    48 Post(s)
    There is a technical bulletin that says that there was an issue with the blower motor brushes.
    bits taken from it as not allowed to post the whole item.
    "Sporadic entry in air conditioning control unit "1273 fresh air blower V2, disruption/Short circuit to earth".
    "Sometimes in connection with entry"1844 control unit for fresh air blower J126, incorrect".
    Technical Background
    Clamping force of carbon brushes intermittently too low.
    The repair operation is to replace the blower motor.
    This is covered on the Audi warranty if you have it.
    2 0 0
  6. Re: Intermittent climate/fan issues
    Jan 2010
    Yate UK
    8 Post(s)
    Thanks for this, mine is having exactly the same issue. My fault code wasn't exactly the same but it did refer to a short circuit. My mechanic had concluded a new blower as well.
    Any idea how much they cost? Preparing for the worst.....
  7. Re: Intermittent climate/fan issues
    Nov 2010
    Middle of nowhere
    Is this the right part number for the fan ? 4F0 820 020 A
    (2.0 tdi, facelift C6)
  8. Re: Intermittent climate/fan issues
    Jul 2013
    48 Post(s)
    That's the no for the blower on the Russian site and when you Google it it comes up as the motor.
    There may be a model letter change if they have upgraded the unit.
  9. Re: Intermittent climate/fan issues
    Nov 2010
    Middle of nowhere
    I found the actual part number after a bit of investigation under the bonnet which is 4F0 820 155 F
    There are no recalls on this and not covered by warranty according the local Audi dealer.
    I'm tempted to get it out and take it apart for a good clean but it looks like a right PITA to get it out!!
    Anyone managed it successfully? It looks like the wipers have to come off and everything.
  10. Re: Intermittent climate/fan issues
    Jul 2013
    48 Post(s)
    Get your dealer to look up
    Technical product information Transaction No.: 2026342/1
    A4, A5, Q5, A6, entry on fresh air blower V2 in air conditioning control Release date: 10-May-2011
    as this says warranty account codes on it.
    Then see what they say and this is for 2009 onwards models
  1. B5 climate fan not working
    By Grover2000 in forum VCDS - Help Requests
    Last Post: 02-07-2011, 09:20 PM
  2. Please Help Climate control- intermittent issue
    By reevelee in forum Golf MK5 - 2004 - 2009
    Last Post: 01-08-2010, 08:44 PM
  3. 04 A3 Climate Control Fan Stuck On
    By PaulA3 in forum Audi A3 - Archive Topics
    Last Post: 08-09-2007, 10:55 PM
  4. Blower Fan Intermittent
    By MikeA4tdi in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 04-05-2007, 07:01 PM
  5. Climate Control Display Intermittent
    By oakhills5093 in forum Archive posts
    Last Post: 06-02-2007, 10:28 PM
