Thread: P0046 3.0 tdi 2005 solved. Limp mode
  1. P0046 3.0 tdi 2005 solved. Limp mode
    Dec 2013
    sevenoaks
    Long time lurker first time poster, so I thought I would post my solution as googled the *rap out of it before I managed to clear the issue.
    symptoms
    from cold, hit 2000 ish rpm, glow plug light flash, limp mode, stop switch off start carry on, all fine, although boost seemed low.
    if I carried on driving without switching off, it CEL.
    Cleaned maf, check for vacuum leaks, all ok, found that the turbo actuator moved freely, but there was a slight notchiness if i pushed the arm backed to starting position manually. So I guess the vanes were coked up. Took the plunge, unbolted exhaust side of turbo, created a blanking plate from cardboard using gasket as a template, used half a can of mr muscle oven cleaner, in the exhaust side, left for 10 mins, worked actuator, and it freed up completely. Left another 10 mins, I shop vacuumed what I could back out, old wickes wet dry vac that's on its last legs, bolted up, started up, all sorted. That was a week ago. No problems. Car goes like a rocket, I can't believe how well it's running. Oh changed oil directly after, using one of those Pela jobs. Checked codes, I use the torque pro app and a bluetooth dongle, all clear.
  2. Re: P0046 3.0 tdi 2005 solved. Limp mode
    Mar 2017
    swindon
    Hi, That's a result... I have the same problem with mine. Has the fault stayed away? I'm very tempted to remove my turbo and give it a proper clean out if it works.
  3. Re: P0046 3.0 tdi 2005 solved. Limp mode
    Jul 2008
    Lisburn
    15 Post(s)
    this is good to know, i stated to get the symptoms and got the carbon clean - it did improve the performance but if its still there... i also just changed the boost controller, wish i had of found this first to check the movement.
    ill maybe suffer it until she is due an oil change which isint long, get my mini back on the road and take her off the road for a day or 2
    Stewart
    2012 Q5 2.0D quattro S line Plus
    1986 coupe quattro (kv)
    1972 mini 1400 100BHP A series
    2016 F-Pace Portfolio X761 2.0D 180HP
  1. Overboost and Limp Mode problem solved.
    By Big G. in forum Golf MK4 - 1999 - 2004
    Last Post: 15-08-2019, 08:44 PM
  2. Please Help 2005 phaeton auto box in limp mode? stuck in gear
    By nitro_uk in forum Phaeton
    Last Post: 12-04-2013, 02:24 PM
  3. Replies: 5
    Last Post: 07-02-2013, 06:52 PM
  4. Please Help Audi A3 Dsg 2005 - limp home mode. gearbox? turbo? ECu?
    By stumaz in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 08-06-2011, 10:41 AM
  5. a6 tdi limp mode (still)
    By viperwhite in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 25-04-2011, 05:00 PM
