Thread: no power to the 02 sensors heating circuits from ECU fault code bank 1 sensor 1 open circuit
  1. no power to the 02 sensors heating circuits from ECU fault code bank 1 sensor 1 open circuit
    Nov 2013
    O2 sensor fault coming up bank 1 sensor 1 code p1030 open circuit malfunction. 02 sensors changed twice still fault code active and Engine light on . Changed Maf , checked fuses all ok . Electrician tested current flow and said that nothing is flowing to ecu from O2 sensor and there is no power to heating circuit bNk 1 sensor 1 .He thinks it might be an ecu problem but I'm not sure as car is late 2007 and not having Any other faults . Car starts fine no smoke , not much rough idle , no misfire , no heavy juddering. He checked all wiring and all was ok and no vacuum leaks either . Could it be ecu fault issue? If it's ecu not picking up current would this be a fixable Any ideas please
  2. Re: no power to the 02 sensors heating circuits from ECU fault code bank 1 sensor 1 open circuit
    Nov 2013
    Any ideas please
  1. Replies: 16
    Last Post: 03-07-2022, 08:15 AM
  2. Hall Sensor & Patriculate Filter Bank 1 Fault
    By Jaggy74 in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 18-07-2012, 09:30 PM
  3. HELP Fault code: IMRC Inlet Manifold Runner Curcuit - open circuit
    By OliB in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 04-12-2010, 12:00 PM
  4. Help: Fault code IMRC- Inlet Manifold Runner circuit, open circuit.
    By OliB in forum Audi A6 - C4 Forum - 1994 - 1997
    Last Post: 04-12-2010, 11:47 AM
  5. TDI glowplug "Open Circuit" fault code
    By TheMatador in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 22-03-2010, 09:14 AM
