Thread: Traffic sign recognition nearly coded
Page 17 of 22 FirstFirst ... 71516171819 ... LastLast
Results 161 to 170 of 217
  1. Re: Traffic sign recognition nearly coded
    Nov 2017
    polen
    I flashed the 8e driver on 4G0907107E
    I wrote to the VCP support for ZDC to "E" We will see what they will answer.
  2. Re: Traffic sign recognition nearly coded
    Dec 2017
    Taiwan
    Activate successfully with VCDS!
    Traffic signs display is working~
    2012 A6 4G c7 TDI
    Thanks for your help ^^
  3. Re: Traffic sign recognition nearly coded
    Jun 2016
    Belgium
    Cool!
    Can you please provide all coding steps for this? I want to do the same on my A8L 4H 2011.
    Thank you!
    2011 A8L - Anniversary Edition
  4. Re: Traffic sign recognition nearly coded
    Dec 2017
    Taiwan
    Quote Originally Posted by Dangerell View Post
    Cool!
    Thank you!
    There are just 3 steps have to do on My 2012 a6 c7 (RMC MMI).
    I can see the options is like "Traffic sign Recognize ...... installed" in the 3 controllers.
    - 8E Image Processing, Long Coding
    - 82 HUD,
    Long Coding
    - 17 Instruments, Long Coding
    After actived, It is working ^^
    Good luck and Enjoy it.
  5. Re: Traffic sign recognition nearly coded
    Dec 2015
    Guildford
    OK guys. So far a lot of discussion about this topic but no results so it is time to reveal the secret. See my step by step guide here: Dropbox - Audi Traffic Sign Recognition Retrofit Guide rev1.pdf
    Rev 01 added today 24.08.2018
    0 2 0
  6. Re: Traffic sign recognition nearly coded
    Oct 2017
    Norway
    Nice writeup/guide!! I had to buy the dongle to get mine to work, but I only got the vcds tool and not the other coding tool available..
    Is it possible to get the other traffic signs showing? I only get speed limit signs. With vcds??
  7. Re: Traffic sign recognition nearly coded
    Dec 2015
    Guildford
    So far on my local journeys I got only speed limits. But in adaptation channels they are options for:
    - end of speed limit sign
    - no overtaking sign
    - supplementary signs e.g showing time when the speed limit is applicable or weather conditions
    To change the above you can use VCDS only as per instructions in the guide.
    I ended up buying VCP interface which was just a bit more expensive than Kufatec dongle and now I can use it for lots of other things above VCDS.
    Sent from my GT-I9505 using Tapatalk
  8. Re: Traffic sign recognition nearly coded
    Feb 2016
    Hungary
    116 Post(s)
    Quote Originally Posted by watronik7 View Post
    OK guys. So far a lot of discussion about this topic but no results so it is time to reveal the secret. See my step by step guide here: Dropbox - Audi Traffic Sign Recognition Retrofit Guide rev0.pdf
    Wow, what a magnificent and quality Christmas gift, thank you
    Audi Q7/4M MY2016, 3.0 TDI/200 KW Quattro
  9. Re: Traffic sign recognition nearly coded
    Dec 2015
    Guildford
    Quote Originally Posted by AT. View Post
    Indeed, I did it over Christmas. Every little helps
  10. Re: Traffic sign recognition nearly coded
    Feb 2016
    Ljubljana
    Hello Watronik7,
    I used your guide and my traffic sign recogntion is still not working. I still get "out of operational" area message. I am living in Slovenia, I have Audi A7 2010 with lane assist and adaptive cruise control and my 8E camera have the number 4g0907107b (so traffic sign should work). I have both VCP and VCDS so I did all the steps described in the guide. I have all the menus in the mmi and instrument cluster, but there is no traffic sign recognition working.
    Have any idea?
  1. Traffic Sign Display missing
    By Evil Dan in forum Golf MK7 - 2013 - 2019
    Last Post: 11-09-2013, 11:52 AM
  2. Voice recognition issue
    By ttamlleb in forum Audi A6 - C6 Forum - 2005 - 2010
    Last Post: 02-08-2013, 04:08 PM
  3. Passat SE Voice Recognition
    By laurona12 in forum In Car Entertainment
    Last Post: 16-07-2011, 10:33 AM
  4. Code Fault Recognition
    By csducks in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 21-01-2010, 10:10 PM
  5. Voice Recognition - No Function
    By Blackavant in forum A6 - S6 - RS6 - - Archive Topics
    Last Post: 06-04-2009, 03:09 PM
