Thread: Emission Control System light has come on, is it harmful to drive?
Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
  1. Re: Emission Control System light has come on, is it harmful to drive?
    Nov 2013
    London UK
    Chris,
    We cleared it and restarted the car and the engine light came on immediately. Silly us did not re-scan but I am taking it that the same faults must be there though for the light to come back on?
    Unfortunately I wont be able to rescan it as I have come back home now.
  2. Re: Emission Control System light has come on, is it harmful to drive?
    46 Post(s)
    Ok no worries, I only asked as the only recent fault to worry about is as below as I see faults from January and February 2013.
    004120 - Intake Manifold Runner (Bank 2)
    P1018 - 001 - Lower limit not reached
    Freeze Frame:
    Fault Status: 01100001
    Fault Priority: 0
    Fault Frequency: 18
    Reset counter: 255
    Mileage: 91703 km
    Time Indication: 0
    Date: 2013.10.12
    Time: 10:14:54
    Freeze Frame:
    RPM: 756 /min
    Torque: 62.4 Nm
    Speed: 0.0 km/h
    Voltage: 13.53 V
    Duty Cycle: 80.9 %
    Duty Cycle: 88.8 %
    Duty Cycle: 80.9 %
    17426/P1018/004120 - Ross-Tech Wiki
    Means then you need the repair kit documented a few times on here -
    Audi V6 TDi 2.7 & 3.0 Inlet Manifold, Swirl Flap Repair Kit.
    VW AUDI Forum - VWAF
    etc.
  3. Re: Emission Control System light has come on, is it harmful to drive?
    Nov 2013
    London UK
    Chris,
    Very kind of you. I have ordered the repair kit. The fault is on bank 2. Is that the easily accessible one or the hard one? Just my luck if it's the hard one. I ordered two, my thinking being that I may as well replace them both as Gupsterg mentioned they are a slightly improved design on the original.
    Thanks.
  4. Re: Emission Control System light has come on, is it harmful to drive?
    46 Post(s)
    No idea as mine have been replaced a few times under warranty so need to get my fingers dirty
    Have a look through that thread(s) and see what they say.
  5. Re: Emission Control System light has come on, is it harmful to drive?
    Nov 2013
    London UK
    Thanks Chris.
  6. Re: Emission Control System light has come on, is it harmful to drive?
    Apr 2014
    Birmingham
    I wanted to create a new topic but I think I can sneak in here too His Emission Control System light has come on 57 346 miles or something... Mine Emission Control system light came on 57 300 miles or something the 1st time. I scanned, cleared, the light was of for 300 miles then it came on again after lacking the turbo. Engine switch off, switch on, turbo works fine again. That happened only 10 times and never again. Now 58 000 miles or something the Emission Control System light came off ITSELF (itself) I didn't scan or clear anything after the 1st time. I believe that the Emission Control System light can switch off by itself. My problem is the turbo, I'm still investigating and I may create a new thread for that matter if the light comes on ever again
  7. Re: Emission Control System light has come on, is it harmful to drive?
    #17
    46 Post(s)
    The light may go off but the fault is still present, the car doesn't automatically fix itself you know.
    Your statement "lacking the turbo" means the car has gone into limp mode and needs investigation.
  1. New Q5 - Emission Control Light on - safe to drive 400 miles?
    By big ironman in forum 2.0TDi - Engine
    Last Post: 01-04-2013, 07:56 PM
  2. Emission Control System Light?..help!
    By jamiepitt252 in forum VCDS - Help Requests
    Last Post: 25-10-2010, 09:35 PM
  3. Emission Control System Light
    By nwells in forum Audi A4 - B7 Forum - 2005 - 2008
    Last Post: 30-12-2009, 12:24 AM
  4. emission control system light
    By d.c1968 in forum VCDS - General Questions
    Last Post: 17-11-2008, 06:02 PM
  5. Emission Control System Light Warning
    By OliSmi in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 27-01-2008, 11:23 PM
