Thread: 1999 polo 1.6 Auto AEE code
  1. 1999 polo 1.6 Auto AEE code
    Jul 2007
    Polo cut out after Kangeroo-ing and would not start on Saturday 28th December. Towed it home and had these codes from Snap On scanner:
    00529 rpm info missing No signal intermittant.
    00519 Manifold Absolute Pressure SNS-G71 Not a plausible signal
    00282 Throttle pos Actuator V60 Short with Ground.
    Looked at it today and tested feed to Distributor pin 1 and 3 and got almost battery voltage. Cranked with coil lead off and nice spark. Cranked with plug out and connected to lead..Good spark.
    Sprayed a bit of easy start in Throttle body and it started. Ran fine till it warmed up a bit and has bad missing on hard acceleration(new Good leads and plugs fitted very recently)
    Checked codes after missing badly on acceleration and "no codes stored"
    Looked up codes on autodata and it says that 00529 is distributor(crank sensor)
    Thinking of going with distributor?? Any other suggestions???
  2. Re: 1999 polo 1.6 Auto AEE code
    Aug 2007
    Hook Hampshire
    21 Post(s)
    GKM24, Sorry for renewing this old post but did you ever solve your problem. This seems to be the same fault I have.
    Audi A7 3.0TDi 2011 160k miles, engine code CLAB 204bhp 2WD
  3. Re: 1999 polo 1.6 Auto AEE code
    1840 Post(s)
    One point, on early stuff ignore the missing G40 signal if the engine is not running, it is a small silvery fish of the red tinged variety....
  4. Re: 1999 polo 1.6 Auto AEE code
    Aug 2007
    Hook Hampshire
    21 Post(s)
    Thanks Crasher. Have you looked at my Thread which is next to this one.
  1. Question mk 3 golf aee code won't start
    By neo5 in forum Golf MK3 - 1993 - 1999
    Last Post: 15-09-2022, 06:09 PM
  2. 1999 Polo 1.6 Auto AEE code
    By gkm24 in forum Polo - Derby - Lupo - Fox
    Last Post: 30-11-2013, 04:04 PM
  3. Fault Code Read Needed - Golf Mk3 1.6 AEE
    By SammoVWT in forum VCDS - Users Locations
    Last Post: 05-03-2010, 09:53 AM
  4. Offered - Engine Code AEE
    By jeff_smart in forum Golf MK3 - 1993 - 1999
    Last Post: 26-08-2009, 01:11 PM
  5. Where is idle control valve on AEE Engine code??? URGENT!
    By cara_essex in forum Golf MK3 - 1993 - 1999
    Last Post: 27-03-2008, 03:09 AM
