Thread: Bonnet catch issue
  1. Bonnet catch issue
    Sep 2007
    2000 Passat TDi 115
    Read a number of issues around the bonnet catch sticking and unable to release, which I've experienced, but now I have the opposite issue.
    The bonnet will catch on the safty catch but not lock down properly. It takes a number of slams to get it to shut only for it to 'pop' onto the safety catch once I'm driving. It has also jumped once after being sat outside fine for an hour which set the alarm off!! I can see a little bit of wear on the catch but not sure if this is causing it or if there should be some other things I should look for or if any one else has had this issue before I head off to the scrap yard for a replacement.
  2. Re: Bonnet catch issue
    Pembrokeshire
    22 Post(s)
    first off make sure the cable release isn't sticking at all. push the handle all the way back and see if that helps. if not, remove catch and give it all a good clean. its sticking , thats all. just needs some tlc.
  3. Re: Bonnet catch issue
    Sep 2007
    Thanks, will give it a try tomorrow
  4. Re: Bonnet catch issue
    Jul 2008
    Quote Originally Posted by PhilH1982 View Post
    The bonnet cable is in 2 parts
    I had to replace the cable from the catch to the junction box under the plastic scuttle panel because the outer cable had split and expanded so in turn not allowing enough slack for the catch to close ! Cable was under a tenner from vw
  5. Re: Bonnet catch issue
    Sep 2007
    Yeah eventually got it sorted. Ended up replacing both parts of the cable as we weren't sure exactly which part was at fault at first. The part from the catch to the junction box was corroded and stretched as you say. Got a new cable from the scrap yard, but was interesting that all the diesel Passats had the cables going or gone in the same place, but the petrol ones were fine, assume its to do with where the air intake is located.
    When we first fitted the new cable, the bonnet still wouldn't lock down, but a bit moving round of the cable and its sorted.
  1. Please Help Bonnet Catch
    By venetian-red in forum Passat - B5 Forum - 1997 -2005
    Last Post: 31-10-2012, 07:18 PM
  2. Bonnet catch
    By gleechy in forum Passat - B5 Forum - 1997 -2005
    Last Post: 30-10-2010, 10:15 PM
  3. Bonnet Catch
    By Andyrg in forum Passat - B5 Forum - 1997 -2005
    Last Post: 21-06-2010, 10:28 PM
  4. Bonnet catch sensor thinks bonnet open when it isn't
    By paddtg63 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 12-03-2009, 08:06 PM
  5. Bonnet catch
    By bograt in forum Audi A4 - Archive Topics
    Last Post: 14-08-2007, 02:13 PM
