Thread: Vibration on acceleration
Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
  1. Re: Vibration on acceleration
    #11
    Dec 2015
    Montenegro
    Hello again,
    Thanks a lot... I have changed both inner CV joints and its better than before, but still there is a bit of vibration which can be felt. Its at 60km/h when going uphill and when cruising at 110km/h. At other speeds it is OK. The cv joints that i have put in my car are from Meyle, but not doing a great job and OEM ones are too expensive...
    Anyway thanks a lot for the prompt answer.
  2. Re: Vibration on acceleration
    #12
    Dec 2015
    Montenegro
    Hello again,
    Thanks a lot... I have changed both inner CV joints and its much better than before, but still there is a bit of vibration which can be felt. Its at 60km/h when going uphill and when cruising at 110km/h. At other speeds it is OK. The cv joints that i have put in my car are from Meyle, but not doing a great job and OEM ones are too expensive...
  3. Re: Vibration on acceleration
    #13
    Oct 2019
    Scotland
    I have a 1.9 TDI EOS with the Vibration on acceleration it is a automatic gear box will it have a DMF or will I Look strait at the CV joint
  4. Re: Vibration on acceleration
    #14
    Sep 2009
    Cadiz Spain
    Quote Originally Posted by SmithD View Post
    As far as I am aware, it will have a DMF, but the CV joints are easier to diagnose and cheaper to replace. To change the DMF you need to take the drive shafts off anyway, and the CV is attached to them, for me it was the interior end of the drive shaft, on the right side prop (as if you were sat in the drivers seat)
    hope this helps some
  5. Re: Vibration on acceleration
    #15
    Jul 2019
    This is a common problem, when mechanics change the DMF somehow they **** up the inner C.V Joint. I think they are not putting it together right. Happens too many times to be coincidence.
  1. Vibration / judder on acceleration - esp in high gears when engine under load
    By JamesRT in forum Passat - B6 Forum - 2005 - 2010
    Last Post: 09-03-2017, 09:04 AM
  2. Acceleration Gone
    By vic4 in forum Audi A3 - 8P - 2004 - 2012
    Last Post: 25-05-2015, 05:05 PM
  3. Question Gearknob vibration under acceleration
    By djmx5 in forum Passat - B5 Forum - 1997 -2005
    Last Post: 13-10-2010, 08:32 AM
  4. Vibration under acceleration
    By MudSurfer in forum Audi A6 - C5 Forum - 1998 - 2004
    Last Post: 21-02-2010, 12:57 AM
  5. vibration on acceleration
    By LLB in forum Passat - Archive Topics
    Last Post: 14-02-2008, 10:32 PM
