Thread: BBK valve cover gasket replacement
Results 1 to 10 of 11
  1. BBK valve cover gasket replacement
    mjhamilton Guest
    So on installing my K&N I noticed the line at the bottom of the valve cover was a little moist with oil - at 80k I am assuming the notorious valve covers will need refreshing and I am using slightly more oil with no apparent burning or other issues
    I have found the instructions to do this and all looks pretty straight forward, I would just need to take care with the lower back screws and use the right bit
    LH - https://skydrive.live.com/view.aspx?...=WordPdf&wdo=1
    RH - https://skydrive.live.com/view.aspx?...=WordPdf&wdo=1
    I have a few questions before I commence on this journey
    1 - At no point does the process mention any requirement for a sealant to be used - is this correct are these things self seal?
    2 - Is the best place to get the kits Audi or are there better 3rd party ones out there, there are companies in the US who claim to make more robust kits which I can get when I go there in Feb?
    3 - My valve covers look like they are peeling so I guess the insides will be a little grim, do you think I will get away with stripping and spraying myself?
    Answers on a postcard please
  2. Re: BBK valve cover gasket replacement
    mjhamilton Guest
    Ideas anyone?? If not I will just get the gasket sets from audi next week
  3. Re: BBK valve cover gasket replacement
    mjhamilton Guest
  4. Re: BBK valve cover gasket replacement
    mjhamilton Guest
    Ok so I confused the guy at audi who couldn't work out what bits I needed for this job - the system is very confusing and each page contradicts the next
    I am off to the US in February on business and can pick up some victor reinz gasket kits for $70+tax all in - this is for the gaskets and all the other seals and parts
    The audi kit looks like it is going to be this in ££ so basically twice the price
    Anyone had any experience with the reinz kits?? Are they good and a worthy alternative??
  5. BBK valve cover gasket replacement
    mjhamilton Guest
    So the parts guy came up with a number of £96 for all the bits
    Was just arranging to have the Reinz kits delivered to a friend in the US for £45 so I would collect when I get there and then someone told me audi to kits
    I specifically asked the parts guy if there was a kit and he went away to check and then said no
    Turns out the kits from audi are £60 delivered so will be ordering tomorrow
    Go figure
    Socialist wants £245 to so the job inc parts so I will have a hash at it myself
    Still unsure about whether I need any sealant - the workshop instructions do not mention it at all
  6. Re: BBK valve cover gasket replacement
    Feb 2014
    West Sussex
    so today the Terraclean process clearly showed my oil leak on the drivers side cylinder bank - oil seeping out and smoking off the manifold - have the bits and just need to find the time and inclination
  7. Re: BBK valve cover gasket replacement
    Mar 2009
    Hi any update on doing the work ? I need to do the same on my car , do you have the parts list so I can order them from Audi? Cheers
  8. Re: BBK valve cover gasket replacement
    Feb 2014
    West Sussex
    I have had all the parts in the garage for nearly 8 months and moved house - not got around to doing it yet
    Audi TT Roadster S-Line Quattro in Daytona Grey
    New, shiny and still topless
  9. BBK valve cover gasket replacement
    Feb 2014
    West Sussex
    So finally did this yesterday and no more leaks - very pleased - was a real ball ache, the lower back torx bolts are in a stupid position and required a lot of patience and swatting to remove and install without rounding off - if you round off its game over so the stakes are high
    Today I replaced my oil check valves and installed JHM spacers
    Took a long time in both jobs but broke nothing and got it all done
    My chain rattle is now gone / didn't believe the check valves work work but they have so very happy indeed - I had a few seconds on every start and now have none at all - night and day - all caused by some sticky check valves??? Times will tell
    Intake is a good 20 degrees cooler which helps as well with heatsoak
    2 good days and enjoyed getting my knuckles scraped
    Independent quoted me 5 to 6 hours labour which would have come in at near £500 so well worth having a go myself
    Most of the time was spent cleaning - oil leaks everywhere and big build ups needed cleaning off
    Changed the plugs as well as I had it all apart - old ones had a perfect colour - looked inside the inlets whilst the manifold was off and everything looked great
    Very pleased to see the engine is looking good on the inside at 85k miles
  10. Re: BBK valve cover gasket replacement
    Feb 2014
    West Sussex
    Well after 2 weeks all I have done it nip up the intake bolts as the thermal gasket has settled - nothing has exploded and everything is running sweet
    Left the car for 4 day and did a totally cold start and zero chain rattle
    I am still amazed and surprised that this had had suck a dramatic effect - a lot cheaper than a chain job
    The Bentley manual actually states that the check valves should be replaced at any sign of engine chain rattle so it is curious as to why Audi never followed suit
  1. Rocker cover Gasket
    By sam.bird3 in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 14-03-2012, 10:44 PM
  2. Question Changing the Valve Cover Gasket and Cam tensioner gasket
    By FrozenAvant in forum Audi A4 - B6 Forum - 2002 - 2005
    Last Post: 17-11-2009, 11:19 PM
  3. Engine oil leak - Valve cover gasket
    By wheelywonderful in forum Passat - B5 Forum - 1997 -2005
    Last Post: 15-04-2009, 06:41 PM
  4. Valve/Rocker Cover Gasket Change (2.8)
    By joncrowe in forum Audi A4 - B5 Forum - 1995 - 2002
    Last Post: 23-04-2008, 06:50 PM
  5. Rocker cover gasket?
    By tom3011 in forum Golf MK4 - 1999 - 2004
    Last Post: 27-03-2008, 02:21 PM
